You're in the home stretch now, just wanted to congratulate you on the fix! These guys will get you past the finish line soon
this is a different machine, but notice the wireform is above the ledge that's part of the bracket, if that makes sense?
give the wire form a 'help' to pop over into it's resting position, at the moment it's just hanging.
looking at your picture, pull it towards you and then up over onto the ledge.
looking at the other rollover switch wireforms should help it make sense, how the wireform needs to rest.
also making sure it actuates the switch correctly, when a ball is in the trough the switch should be closed, as when it is not the switch should be open.
you've done really well!
Thanks for all the help @rikoshay. I took it apart and put it back, I got the ball to kick out, but now it looks like it wants to kick out non stop and I keep getting the banging noise. Not sure what I did wrong, everything looks tight.
The game thinks the ball is stuck in the outhole so keeps trying to kick it out.
You need to adjust the switch contact gap so the switch contacts don't touch when there's no ball, but do touch when the ball lands on the wireform. Gap should roughly be 1/16"
Quench I dissembled it and bent it to get it to work, but it’s now working! I don’t get any kick backs or noises. Something shot off three times at the end of the game, like 3 gun shots, but other than that loud noise, everything is working fine.
I can’t thank you Rikoshay and everyone else who have helped. Thank you all so much! Yeah
This page was printed from https://pinside.com/pinball/forum/topic/stern-dracula-not-booting-1/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
