(Topic ID: 188603)
Stern DA-300 7 Digit - One segment missing
By hisokajp
6 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by hisokajp
    #1 6 years ago
    Segment 2 of the digits are missing, I have tried hard to fix that display following the http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Display_problems but no dice, getting to the point I don't want to spend the $50 for a new display just for the satisfaction of all that time meaning something...
    Reflowed the pins, no change
    Changed the transistor, no dice
    Changed the decoder, kinda worked for a while or maybe I just dreamt it...
    Changed all (8) 100K ohm 1/2 watt resistors, no change...
    I try tracing what I could see for the Segement E and all seems to check out but no luck.
    WP_20170508_19_16_19_Pro (resized).jpgWP_20170508_19_16_19_Pro (resized).jpgWP_20170508_19_17_13_Pro (resized).jpgWP_20170508_19_17_13_Pro (resized).jpg
    #2 6 years ago
    This is the only source I use for displays repairs. Last step is the segment transistor.
    http://stevekulpa.net/pinball/bally_disp6r.htm
    #3 6 years ago
    it's pretty much a copy/paste of the Pinwiki section, I did replace both the segment drivers and decoders, no dice :S
    #4 6 years ago
    Identify the segment pins on the gas tube for each of the display, and carefully unsolder all but one, centering them in their pins so they aren't making contact.
    See if it works then.
    You could have a bad tube -- sometimes the tubes fail short, and if that segment is short somewhere in the display it can pull down the driver transistor.
    #5 6 years ago
    unsolder all but the one segment (E) that isn't working you mean?
    #6 6 years ago
    The pin that leads to that segment on each digit.
    If you can get one single digit to work with that segment, and it disappears when you resolder another one, then you've confirmed the short in the tube.
    Since these are gas tubes they can fail when energized but it won't be obvious if you just try to measure resistance with a meter to confirm it.
    #7 6 years ago
    tried that out, unsolder all but segment E and nothing was showing on the display... I am fresh out of ideas and I am thinking $50 for a new display is more reasonable at this stage.
    This page was printed from https://pinside.com/pinball/forum/topic/stern-da-300-7-digit-one-segment-missing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
