Hey guys,
I have some red wedge LED bulbs in my High Roller Casino, but they seem awfully dim. What’s the voltage spec for Stern coin door bulbs?
Thanks,
Jason
Hey guys,
Thanks,
Jason
6.3 volt incandescent bulbs like #44, #47 and #555 are used on most machines.they come in two shapes.
the #159 bulb is also 6.3 volt at .15amp.
Quoted from JadedHesher:6.3 volt incandescent bulbs like #44, #47 and #555 are used on most machines.they come in two shapes.
Thanks! Much appreciated!
Jason
Quoted from Shogun00:Can you post a picture of the inside of the coin door? It might be the same as what my Robocop had.
Here ya go!
Jason
143CB4FE-1531-4EC7-9AC3-7343E679AF02 (resized).jpegCCB9080C-606D-493E-9BAB-FB7F231052E4 (resized).jpegIt looks exactly the same as my Robocop. The light suppose to go through a hole, but instead the light bounces all around it. It makes a basic LED look very dim.
There are a few ways to resolve this.
Use a bulb that has 4 LEDs on it. These are super bright, which pushes more light through that hole.
https://www.cometpinball.com/products/4smd-bulbs
Use a LED flex bulb, so you can get the light properly aimed into the hole.
https://www.cometpinball.com/products/1smd-flex
Buy a retro LED bullet bulb. They look just like a traditional incandescent bulb and fit through that hole perfectly. This is what I did with my Robocop.
https://www.cometpinball.com/products/retro-smd-bullet-bulbs
Quoted from Shogun00:It looks exactly the same as my Robocop. The light suppose to go through a hole, but instead the light bounces all around it. It makes a basic LED look very dim.
Can’t thank you enough man!
Jason
Quoted from Yoeddy:Can’t thank you enough man!
No problem! Here are a couple of photos of the LED bullet bulb in my machine. I went with the clear lens natural white.
20210903_040731 (resized).jpg20210903_041010 (resized).jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/stern-coin-door-wedge-bulb-voltage- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
