I found a pile of gold metal flakes in the bottom of my ACDC Premium today. Took a while but finally determined that the brass piece in the flipper coil stop was loose and when it gets hit with the coil plunger it must be getting a slight shave job every time.
I also was working on Tron and sure enough I found another pile of gold dust. Exact same problem on another coil stop...loose brass piece.
Anyone else have this problem? If not I would take a look in your newer sterns and look for piles of gold dust in the cabinet.
Also do you think the best solution is to replace the coil stop? Seen another (sort of related) thread where they put electrical tape on the brass piece but not sure I like that solution.
