That's fairly standard condition for those boards, though it's actually very repairable. You'll definitely need to replace the male header pins and rebuild the female side of the connectors with Molex trifurcon contacts. If the bridges are all good, you can leave them or top mount more robust bridges with heat sinks. Examine the fuse holders and replace any burnt or oxidized contacts.
Check out the Bally/Stern section on pinwiki. Pretty thorough guide to rehabbing these boards.
I would fix it. but how do you decide if a hobby is *worth doing* ?
How can we know your skills tools and resources ? Got a good iron? good desoldering technique? access to the proper parts? time?
its time vs reward ...but its an original part for a collectible ..
Only you can decide if you should do it .. but please .. if you do it ..do it properly...
Solder skills are getting better each time I do something.
I'm pretty patient. Spent 3 hours yesterday tweaking my sparkly new DW moving topper (getting that base to sit over the mechanism is a treat). Rebuilt the the GI connectors on DW today too.
But back to Catacomb... The question is: should I re-do the BR too? I can't tell if the heat damage is from the solder job or new excessive heat. Are there any clues?
I'd rather not replace the BR if not needed. Other than a GI problem, the game works fine.
Oh, and one other question: Any way to clean up all that burnt flux? I've been doing some reading. I keep seeing alcohol as a solvent with some kind of brush (toothbrush??).
Thanks,
faz
This one really depends one what you FEEL like doing. To rebuild a power supply the way it should be done can cost you about 75% the cost of a new one.
Sometimes, I enjoy the feeling of doing it myself, especially if I have all the parts lying around ~ bridge rectifiers, heat sinks, fuse holders, fuses, pins, diodes, etc. But if I'm low on parts, I have no problem parting with $60 ( or whatever ) for a repro. It is the muscle behind the whole operation afterall, and its money well spent to have a reliable and stable power supply.
You can test to see if the BR is bad. No need to replace if it tests fine, but I would put on new thermal paste and ensure the bar is inplace if u keep old. Replace all the .156 pins on board and female connectors. (Double check contunity on top / bottom of board for traces). I usually replace the HV diodes while I have it out.
Cleaning up flux use a toothbrush with some alcohol. Good luck!
sounds great.
you can buy proper flux remover or isopropyl and a toothbrush probably works too.
random example - http://www.hmcelectronics.com/cgi-bin/scripts/query.cgi?query=flux+remover
there is no doubt somewhere that has it better / cheaper / closer .. but thats the stuff
if you look at the many youtube vids you can learn how to test BR with a meter.
heres one -
personally I only replace them if they are old, weak or the wrong size but they arent real expensive so if you want to really sort the board well get new ones to be sure
Quoted from schmoo:To rebuild a power supply the way it should be done can cost you about 75% the cost of a new one.
75%? Maybe I am just buying stuff in bulk but this costs me under 15 bucks to rebuild the entire board including female connectors...
If it were me, I would just rebuild the board. I enjoy working on the games and bringing them back to life.
Check big daddy enterprises. He sells kits to rebuild these. Or buy parts from Ed at GPE.
I usually have main parts(headers, connectors, fuse clips, and bridge rectifiers) on hand needed to rebuild these. If i rebuild one, I always replace the BR's and move them to front side.
Well, I appreciate all the encouragement. I just finished with what I planned to do, but wondered if I need to do more.
As I said before, all three BR test good.
All I did was to rebuild the header pins of two of the three connections.
Clean up all the burnt flux (that burn on BR1 was prior art from another artist).
I rebuilt the matching two connectors one slightly toasty, one melted and severely burnt.
The last connector and pins looked really good. I'm of the opinion that if it looks good leave it alone, so rebuilding the header pins of the third connector seemed unnecessary. I could rebuild the connector with new trifurcon pins...easy and low fubar potential.
I'd appreciate an opinion before I wire it back into the game.
faz
You did good work there. The header pins you did not replace is the input from the transformer. These header pins never burn for whatever reason, so you dont always have to replace that one. The fuse clips look in good shape.
Use some heat compound if you got it on the birdges against the heatsink.
If they have good tension and aren't damaged or corroded you can leave the original fuse clips in there.
I usually rebuild all three connectors regardless of how they look. All of the electricity used in the game flows through this board and I don't like trusting 30 year old connectors to this task. Contacts lose their tension, header pins become oxidized, plus the current rating of Trifurcon contacts is much higher than the original single sided contacts. Might as well take care of it now while you're under the hood.
Ok....this just officially got weird.
I went to start rebuilding the second connector when I noticed that the two connector pin slots most burned...have NO WIRES! what-the-what?!?! Both GI...both way toasty.
I have no extra wires lurking in the cabinet. I can't find a harness diagram for a Stern, just the Bally. Am I missing two wires or did someone just replace one burnt connector with another burnt connector (burn from another game).
Looking at the schematic. J1.1 and J1.2 share the same connection...but is it possible that the wire was on J1.1 initially (J1.2 empty) and the op rewired to J1.2. J1.8 seems to share a connection with J1.5 (GI Bus). Again, wire was initially on J1.8 and moved to J1.5.
I tried tracing the schematic on the MPU but cannot make it out too blurry. It seems bizarre that Stern would leave two wires off a connector and even more bizarre that an op would cut an extra GI wire that carries half the load all the way back to the backbox.
btw...thanks for the feedback.
faz
There is redundancies on the connector pins. I have seen people get creative and move wires around to avoid a burnt pin.
The bally pin outs are identical, and i think stern even used all the same wire colors so you can reference that while being careful. Good idea to trace out any wires if you are not confident where they go.
Also i think stern lists the wire colors somewhere, but not as clearly as bally did.
*** SORRY *** I could a few errors copying down the trace. Fixed (well it's what is in my machine).
I thought Stern and Bally shared a lot, but using Steve Kulpa's Bally page I tried to map but it was not even close. I was using the AS-2518-18 notes... looked really close, but I noted board differences in the traces and the J1 configuration.
For the record: Steve's color/config notes for J2 and J3 map exactly to my game.
Regarding J1
First off, he says there are 9 pins. The board and my connector have 8. I saw in Clay's guide that the 9-pin is only used on the AS-2518-49...so, disregarding J1.9 I'm going to assume the rest is correct.
I've traced through my wires. I'm not 100% of the gauge, but Steve notes 18 and 20 ga in this area. This connector is all "fat"... so, I'm going with 18 gauge all around.
J1.1 no wire
J1.2 Solid Red
J1.3 Solid Dark Blue (same color as J1.7)
J1.4 key
J1.5 Solid White
J1.6 Dark Blue / white Stripe
J1.7 Solid Dark Blue (same color as J1.3)
J1.8 no wire
I traced the wires...did not pull the bulbs to isolate circuits, but I get to the right neighborhood (GI, Coil, Feature).
J1.1 -
J1.2 Red - GI
J1.3 Blue - Switched Lamps (share circuit w/J1.7)
J1.4 -
J1.5 White GI
J1.6 Blue w/white - Coils
J1.7 Blue - Switched Lamps (share circuit w/J1.3)
J1.8 -
When I got this game it worked 100% and I did not change the connector. This connector and J3 was always a little toasty (a lot toasty). After the GI died last month, I thought I would open up Pandora's box.
I compared my traces to what's in Steve's guide and Clay's guides.
Anyone care to check this hypothesis:
J1 - Burned...abandon
J1.1/ J1.8 were swapped, but since they are both GI... the game does not tell the difference..so it still works with the ground on the wrong side of the lamps.
J1.2 was used instead of J1.1....don't know what happened to the green wire (no sign anywhere).
J1.3 confuses the heck out of me because it's supposed to be unused, yet there's a shared CPU controlled wire on there....AND J1.1, J1.2, J1.3 all appear to be ground.....is the ground side of the computer controlled lamps??
J1.4 is the only no-brainer I have going for me....the key lines up
J1.5 wrong color...but looks GI-ish
J1.6 wrong color...but looks coil-ish *** CORRECTED ***
J1.7 wrong color...but looks to be feature lamps *** CORRECTED ***
J1.8 appears swapped with J1.1
I'll hold my thoughts on straightening this out...but I'm starting to get some ideas.
I'd appreciate a more informed opinion of my hypothesis.
This was a very interesting exercise. I feel my pin-repair understanding just went considerably.
TIA,
faz
Post edited by pinball_faz : Typo in wire mapping
Have you looked at the schematics posted on ipdb.org?
http://mirror2.ipdb.org/files/469/Stern_1981_Catacomb_Schematics.pdf
This just keeps getting weirder.
I looked over the PF again.
This is getting confusing. I made an error with these damn designations... I fixed the above post.
Other info:
Every GI has two red wires soldered to the base... except if it is the last lamp on the string..then only one.
Every GI has two white wires soldered to the tip...except if it is the last lamp on the string..then only one.
Every feature lamp has two solid blue wires soldered to it's base until it hooks into an uninsulated common ground wire (the feature lamp "toast" is all uninsulated common).
Most coils have two yellow wires on a lug...more on that in a bit.
I tried to trace the red wire since it's big and bright. I see one red wire enter the bundle but two leave. The bundle itself is a 1" mass that has 27 zip ties all along the bundle. Finding a cut red will require me to open up the wire bundle.
But then it occurs to me. Are all these pairs of wires really a daisy-chained to the next device? I thought it was just the GI doubling up on wire to handle the higher demand.
I found what looks like a daisy chain on the coils. The blue wire with a white stripe (coil) appears only once on the playfield..so really easy to trace. I think it ties to a lug on the right flipper, then pigtails to a fuse (between the flippers) lug with another pigtail off the same lug of the fuse to the left flipper coil. The other end of the fuse is the bright yellow wire...and there are two yellows at that point, I think they loop around to the coils until they dead-end at one drop target.
If so, a lot of the confusion is starting to make sense....except:
The blue wires bug me though. One of these solid blue wires should be my for feature lamps...and if they are daisy chained like the other GI/Coil wires....then what's the second wire coming out???
J1.3 is a ground, J1.7 has +5.3vdc.
Furthermore, it looks like this whole game is run off one GI BUS and one GI Bus return...which means, it's just going to burn again. That's why I'm assuming there's a 2nd GI feed of each (Green, Orange). Is only one line of GI "OK" for a Catacomb? There seems like a lot of lamps under there.
Thoughts?
faz
"J1 - Burned...abandon
J1.3 confuses the heck out of me because it's supposed to be unused, yet there's a shared CPU controlled wire on there....AND J1.1, J1.2, J1.3 all appear to be ground.....is the ground side of the computer controlled lamps??"
I don't think J1-1 was swapped with J1-8. On my flight 2000 J1-1 is ground and J1-8 is 7.3 vac. J1-1 could have been swapped with J1-2 - both ground.
J1-8 could have been swapped with J1-5 - both are 7.3 VAC.
I just finished working on my connectors. I’m NOT an expert but this is what I have on J1:
Pin 1 is red (ground)
Pin 2 is empty – but is connected to ground.
Pin 3 is blue – feature lamp bus (5.4 VAC)
Pin 4 Key
Pin 5 is empty – but is connected to pin 8 (7.3 volts ac)
Pin 6 is blue – white – solenoid bus (43 VDC)
Pin 7 is blue – feature lamp bus (5.4 VDC)
Pin 8 is white – Gen. Ill. Bus – and is connected to pin 5 (7.3VAC)
I think you have the same thing except 1 and 2 reversed and 5 and 8 are reversed. (or maybe mine are reversed)
Here is a lousy picture of my connector.
Bob
Ok, so maybe Pandora is not as fubar as I thought...game specific wiring?
Catacomb owners.... Can I get a few people to check the J1 connector on the rectifier board?
Color of wire and order would be greatly appreciated.
Thanks,
faz
I got report of another Catacomb with the same wire pattern as your machine Bob.
Ready to re-pin the connector.
faz
Well...it's done! Santa delivered!
I finished up the board. Repinned the connector and just plugged J2 alone in....just to make sure all the testpoints delivered the correct voltage.
All was great except for TP1. I double checked the work and I found the problem....it appears the F1 fuse holder was weak not applying enough pressure. I cleaned and crimped the fuse holder a little tighter and the correct rectified power came shooting out TP1
Too bad nobody suggested I replace the fuse clips...
Quoted from wiredoug:perhaps this is a good chance to install new fuse clips?
To anyone trying this for the first time. I rank the whole process a 3 on the difficulty scale. That was only because of the non-standard wiring from other sources. The soldering was not bad at all but the research to make sure I did not blow up something took far longer than I hoped.
For my Catacomb at least, what's documented in this thread for J1 is consistent with "oldschoolbob" and "drdave" (RGP). Plus, the game works 100% (got my GI back too with the rebuild J3 connector) so, I add me to the list. Also, having not done this before, it was not painfully obvious to pull the power board. Little did I know that six little screws separated me from a nice simple solder installation of the board on my bench instead of hunched over the machine swearing. Do yourself a favor...pull the whole board with the transformer...so much easier.
One bit that's not really well documented as well is the wires coming out of the transformer. My colors again are different than what clay and others discuss.
For the record:
My transformer is a 16B-6
Tap layout - (Left to right)
Front Top Lugs 14, 15, 16, 2, 6
Back Top Lugs: 17, 18, 8, 10, 12, 13
Back Lower Lugs: 1, 3, 5, 7, 9, 11
14 Green w/Blue stripe (hard to see the blue)
15 White
16 Blue w/White stripe
2 Red w/Yellow stripe
6 White w/Red stripe
17 Deep Navy Blue (really hard to tell from black...which now that I understand what's happening from the schematic...it would not have mattered (7.3v AC).
18 Black
8 Green w/White stripe
10 White w/Green stripe
12 open
13 Orange
1 Red (soldered to 3 for 120 volt setup)
3 open (soldered to 1 for 120 volt setup)
5 Yellow (soldered to 7 for 120 volt setup)
7 open (soldered to 5 for 120 volt setup)
9 open
11 open
On a related note the schematic for the rectifier board does NOT list Tap #5. If you don't look closely you might think E1 goes to Tap #9.
Final synopsis of what was done:
Repinned connector J1, J3
Repinned header J1, J3
Cleaned the board of flux et al
Cleaned the fuses, connectors ..added a little tension.
Heat sink paste added
I hope this thread will be able to help someone in the future!
Thanks all for your help and encouragement.
faz
This page was printed from https://pinside.com/pinball/forum/topic/stern-catacomb-rectifier-board-worth-rebuilding and we tried optimising it for printing. Some page elements may have been deliberately hidden.
