(Topic ID: 191992)
Stern cabinet protection
By DEN
2 years ago
  • 24 posts
  • 9 Pinsiders participating
  • Latest reply 2 years ago by Baiter
#1 2 years ago
Hi guys, would these leg brackets be enough protection for my commin Aerosmith pro?
Or should i protect more?
#2 2 years ago
I use the same style of protectors.
I haven't had a problem yet.
#3 2 years ago
Quoted from DEN:
Maybe someone with an AS pro can confirm it, but all my recent NIB Sterns have come with plastic versions of those attached out of the box and they work great.
#4 2 years ago
Quoted from J85M:
Hmmmmm. Plastic included, i bought metal versions also. But as i read, people say williams metal brackets is the way to go.
#5 2 years ago
I think the metal brackets you are referring to are the ones inside the cabinet to keep the sides from splitting. Not sure though.
#6 2 years ago
Quoted from DEN:
Quoted from ecmurrayf1:
Yeah that was the first thing I thought when I read den reply above.
The ones think you want den are these: http://www.marcospecialties.com/pinball-parts/01-11400-1 they go on the inside of the cabinet and hopefully help reduce/eliminate cabinets splitting.
The ones you posted are basically metal versions of these http://www.marcospecialties.com/pinball-parts/PC-4 you should see a plastic version of these on all 4 corners of your game when you open the box.
#7 2 years ago
Don't new Sterns all come with the leg standoffs? I don't see any reason to buy a second set, even if the original are plastic.
#8 2 years ago
Allright, i see, yea i bought those metal ones, i will replace the plastic ones, but as i understand, it will not bee enough, to hold the cabinet!
Allright will order the williams ones also, dams sterns costcut! But, i have seen the clearcoat job on Aerosmith LE, om my good, its nice done
#9 2 years ago
Quoted from DEN:
No need to replace the plastic ones on the outside of the cabinet they work perfectly, maybe even a little better than metals ones imo, but your righty they wont do anything to hold the cabinet together, they simply keep the legs off the cabinet/decals a few millimetres.
To hopefully strengthen your cabinet you will need the Williams brackets I posted in the link above, good luck and enjoy that ASLE.
#10 2 years ago
These brackets go on the outside.
I always do two things. 1) get metal brackets (if plastic are not included) 2) get felt protectors at the same time. 100% guarantee there will be no rubbing.
#11 2 years ago
I thought the consensus here was not use the plastic they make the decals wrinkle all up but the metal ones don't? None of my machines have decals and I just cut out thin rubber ones and used that.
#12 2 years ago
Quoted from Travish:
Your right, but we are discussing the stand offs that come fitted to all NIB Sterns that keep the legs off the cabinets/decals by a few millimetres. Those where originally metal but are now plastic and work great, one for the few things Stern have added that's an improvement.
I think the OP got mistaken with the protectors he was originally asking about, he wanted to know about the protectors/brackets that go on the inside of the cabinets, that have been highlighted in the canbinet thread to hopefully minimise cabinet seperatation aka splitting, those are metal.
#13 2 years ago
The plastic ones you are referring to are about 3 times bigger than the ones talked about in this thread.
#14 2 years ago
Wont install them on the inside. Will take plastic ones of and screw those metal ones on instead. My early question was, will these outside metal brackets will bee enough protection to prevent cabinet crack on my upcomming Aerosmith pinball.
As i have read. The ones i have bought wont be enough.
How it it with these new stern cabinet cracks. Is it out of the box or after anweeks usage or???!
#15 2 years ago
Quoted from DEN:
I answered your question above in post #6
No those metal brackets won't help cabinets splitting you need the metal Williams brackets that go on the "inside" of the cabinet that I linked in post #6
The plastic leg protectors that have been coming on recent Sterns on the "outside" corners of the cabinet are great, no real need to change them to metal.
#16 2 years ago
But wouldn't metal brackets screwed in help protecting cabinet split more?
The plastic ones are only to protect cabinet decals.
#17 2 years ago
Quoted from DEN:
Classic language barrier .
#18 2 years ago
Quoted from Pinballpal:
Yeah but that's the good thing about this hobby we all try to help each other no matter what, one of the best thing about this hobby is the people. I remember when I was new and had the pinball language barrier what's a VUK, what's a diode do etc etc but those guys stuck with me and I'm thankful they did.
#19 2 years ago
Quoted from DEN:
I think it's more about what you feel will work better, so go with the metal brackets on the out and the Williams brackets I sent you a link for on the inside.
If you don't want the plastic leg protectors pm me! I would be interested in them for an older game I have NIB still, I would take them off you.
#20 2 years ago
Sorry guys, its all my fault. My English is nit that good, but im trying
And thanks for all the help
#21 2 years ago
Quoted from DEN:
Here are 2 pictures of the Williams HD leg bolt braces that mount on the inside of the cabinet for the front legs on my GB Pro. The first picture is the one on the right side of the game under the shooter rod. This was the first pair I put on a game, since then I have put that one on upside down, that being so the plate will now mount higher and put more bracing higher up where there is more cabinet flex. The left side can't be done that way because of the tourniment and start buttons are in the way.
#22 2 years ago
Quoted from MustangPaul:
He is asking if the metal leg protectors he has brought would hold cabinet together better than plastic. Initially there was some confusion regarding leg protectors s and cabinet brackets.
But now I believe he's asking if the metal leg protectors on the exterior of the cab would offer any greater protection than the factory plastic, as I said above I think the metal will offer him better piece of mind and I would be interested in his plastic ones so win win.
#23 2 years ago
Quoted from J85M:
I know, I was just offering up info about what the interior braces look like installed if he wanted to go that route also, which I think he should.
#24 2 years ago
The external brackets offer no support for the cabinet corners, they are just spacers. The ONLY thing they do is keep the legs from touching the cabinet.
Great American Pinball
$ 279.95
Pin Stadium Pinball LEDs
4,500
Sale Pending!
New Albany, IN
$ 16.50
4,800
Steele, ND
3D MODS
