Hi all,
As I was adjusting some wire gates and switches on a couple of Sterns, I was wondering why Stern doesn't use optos on their ramp entrances. In my experience optos on ramps are more reliable than switches.
Just curious.
Hi all,
Just curious.
I wouldn't be confident that it'd be reliable on location. Stern ball trough optos have given me a lot of trouble, and the Tron recognizer entrance opto isn't the most reliable switch either. Physical switches with actuator arms, it's more obvious how to fix and idiot proof than optos.
Optos are probably more expensive too, which is probably the real reason.
How about those trough optos? Its not like I keep a cubby bin filled with those.... (hyperbole, but seriously its the #1 problem on my and my friend's Sterns)
Quoted from DrStarkweather:How about those trough optos? Its not like I keep a cubby bin filled with those.... (hyperbole, but seriously its the #1 problem on my and my friend's Sterns)
I got so tired of screwing with them that I keep two extra sets on hand at all times for quick replacement. Nothing worse than having a machine go down at a party and having to wait a week for parts. Now I just switch them out in about 5 minutes. I have yet to have an led on them go bad, it is always the solder joint and a reflow always makes them useable again. the last go around a removed all the cra factory solder and used a good lead solder. It has yet to go bad again.
Quoted from LTG:Like the set of optos on the top of the ramp on POTC going to the mix master ?
Good one. Those caused all kinds of problems.
When mechanical switches fail they generally just don't work. When optos fail they often times send rapid switch state changes to the CPU causing all kinds of fun.
Optos are normally closed switches as far as the CPU is concerned. When the ball passes through the opto the switch "opens" briefly. But also, when power is interrupted to the opto, the switch "opens" as far as the CPU is concerned. And this is the issue most of the time - cold solder joints on the optos causing power to be intermittent - when this occurs the CPU sees multiple state changes.
So when optos are working correctly they are a nice solid state switch. But when they have issues the problems are more dramatic and many times intermittent and difficult to troubleshoot.
Parker
Parker
This page was printed from https://pinside.com/pinball/forum/topic/stern-and-optos and we tried optimising it for printing. Some page elements may have been deliberately hidden.
