(Topic ID: 127574)
Stern almost killed me
By zr11990
8 years ago
  • 63 posts
  • 37 Pinsiders participating
  • Latest reply 8 years ago by 0geist0
    There are 63 posts in this topic. You are on page 1 of 2.
    #1 8 years ago
    I always hated the way Stern pins slid out of the cab. The W/B setup is so much better. I was putzing with the speaker on this POTC I sold and I had the PF propped up so I could remove the woofer. The metal slide on the left side actually fell off and the pf fell on my back. It scared the shit out of me and hurt like hell and I had to extricate myself from the machine and then locate the nuts and put the slide back on. I think Stern owes me a Kiss LE for my pain and suffering
    11
    #2 8 years ago
    Ouch, did the pin suffer any damage?
    16
    #3 8 years ago
    Stern's slide system does suck.
    22
    #4 8 years ago
    Holy crap! Don't worry, i contacted them and they have some Wrastlmanias laying around for you
    #5 8 years ago
    Quoted from RobT:
    In deed, the playfields have to be almost forced back into place. People always think its broke, I usually comment that the design from the start was broke.
    #6 8 years ago
    At least you located your nuts! I always know where mine are because my warden keeps them on the mantle.
    #7 8 years ago
    Quoted from TheLaw:
    That would be worse.
    #8 8 years ago
    Quoted from TheLaw:
    Add insult to injury
    #9 8 years ago
    I like breakshot's playfield support system
    glad you lived to tell the tale!
    #10 8 years ago
    Quoted from dgoett:
    Capcoms are nice...speaker fold down is great also.
    #11 8 years ago
    Quoted from TheLaw:
    Nice menus controlled with flippers too. Capcom games are neat.
    -1
    #12 8 years ago
    Too bad your lawyer wasn't there to witness it.
    #13 8 years ago
    Quoted from TheLaw:
    Capcoms are nice
    Unless the screws fall out of one side and when lifting the playfield it turns sideways instead of going up.
    Then it gets exciting.
    LTG : )™
    #14 8 years ago
    would of been an ODI POTC..
    (Owner Died Inside)
    #15 8 years ago
    That sounds painful. Just think of all the money Stern saved without designing proper hinges like on all other pinball machines and that should ease the pain.
    #16 8 years ago
    The stern system blows but I'm sure they were a) working around a Williams patent, and b) trying to do it as cheap as possible as they do with everything.
    #17 8 years ago
    Quoted from RobT:
    Its cheap compared to the better style
    #18 8 years ago
    Quoted from bigd1979:
    Yes I think we all understand Stern is being cheap Service rails anyone?
    #19 8 years ago
    Quoted from RobT:
    It has improved a bit from the Data East days.
    #20 8 years ago
    Quoted from o-din:
    Not really, now the prop rod is gone
    #21 8 years ago
    Quoted from 0geist0:
    True. But they did extend the slide rails so you are no longer digging into the wood on the bottom of the playfield. Ever have a mishap on a GnR widebody?
    #22 8 years ago
    Quoted from RobT:
    No joke. I thought at first was just SP but when I got WPT I realized their whole system is dumb. I cracked on plastic on my near flawless WPT because of the playfield dropped and caught the edge. You almost have to try to design it this badly.
    10
    #23 8 years ago
    Quoted from TheLaw:
    On the Wrestlemania's this is actually an implemented feature.
    The play field physically pins you, and then a ref's voice can be heard counting to 3.
    #24 8 years ago
    Holy crap! Are you okay? I was talking to the POTC. Lol!
    #25 8 years ago
    Quoted from inhomearcades:
    That's for sure. It sucks having to lift the back of the playfield up before sliding it back in. I thought it was bad doing it on an older and newer premium / LE's with service rails but with their new pro's without service rails it's even more difficult...
    #26 8 years ago
    Sorry about your Pinjury!
    #27 8 years ago
    Not since SYS9 has there been a more dangerous PF to work on. I Bungie up PFs whenever I work on them. I did a repair on only one Stern and was blown away by how bad the design was. I never trust those prop rods or any propping system for that matter.
    #28 8 years ago
    Quoted from zr11990:
    Gary has authorized RobT to kiss you to make up for your pain but add to your suffering.
    #29 8 years ago
    did they crawl back inside ya or what?
    #30 8 years ago
    ouch, major ouch. lucky that did not knock you out. that could have been bad. passed out in the cab body. sheesh that is bad, I can just imagine how bad that hurt!!!!
    #31 8 years ago
    Quoted from thedefog:
    I had it propped up with a rubber tipped handle that I always use but when the metal rail fell off the prop moved and the PF fell on me. I was bending over removing the speaker so it fell on my back. Since it was tilted to the side it didn't want to move. After I got myself out it was a total bitch to reinstall the metal rail. Its a total shit setup that should be changed but I'm sure it won't because stern is fucking cheap.
    #32 8 years ago
    There is a trick. Push down on the apron/the front of the playfield, it takes the pressure off of the back of the playfield by the pins, it allows it to go in very easy.
    #33 8 years ago
    Quoted from Zampinator:
    Yup and that's why I LOVE the service rails, it makes it even easier. I NEVER use the prop rod.
    #34 8 years ago
    On my TRON game on day I pulled the playfield out too far and it came off the rails. Somehow a corner got jammed under the slide and I could not move it at all. It was completely stuck - I almost had a heart attack. I ended up having to take the rails off to get it out. Thankfully not really any damage but a few nicks that can't be seen.
    #35 8 years ago
    You cant get to the speaker with it sitting on the service rails.
    After all that I cant use the speakers on any of my games so I had to put it back
    #36 8 years ago
    I know that, I slide the pf till it catches on the end of the rails then lean it back against the bb.
    #37 8 years ago
    Quoted from marksf123:
    That happened to me too, landed on my PIG2, I was pretty mad at myself. But also, what a crappy design.
    #38 8 years ago
    Ok I get it. Sterns feel so rickety when you do that because they are not locked into place.
    #39 8 years ago
    Stern copied the SS bally design from the 80's.
    #40 8 years ago
    True it isn't locked in the up position but it's leaning back so far that it will never come down and it will never slide off the end of the tracks because of the up-turns on the ends. That's the way I've been doing it since I got started in the hobby and have never had a problem.
    #41 8 years ago
    I heard if you turn off the lights in your bathroom and splash water on the mirror at midnight and say "Gary Stern" 3 times, a playfield will fall on your head.
    Seriously though, glad you're okay. People get seriously hurt from PFs falling on them.
    #42 8 years ago
    Not lolled but smiled a little bit. Yea, if it had fallen on my head instead of my back it might have been bad. What is funny is my dog was in there with me, as usual, and he stuck his head in the coin door to see if I was alright.
    #43 8 years ago
    Whew, I'm glad to know I wasn't just being overly paranoid, because the entire time I was working on my in-cab Space Shuttle restore I was terrified of that damn thing. As if SS's particular design risking damage to the ramp while raising it wasn't bad enough, the prop rod is an absolutely useless effing joke. Of two nesting locations provided by Williams on the pf bottom, only one is just slightly less than a guaranteed accident - the other is just comically bad - I guess liability suits weren't yet in vogue then.
    I finally cut a length of 1" PVC to use as a prop on the left side. Stores inside the cab too so it's always handy; does wonders for stability but still requires care.
    "But", I told myself, "that was 1984 and they were almost out of business...." And indeed, the system for WW (Sys11) was much better. But sheez, the industry as a whole didn't learn and this is still a risk THIRTY YEARS LATER? For shame.
    #44 8 years ago
    Quoted from goingincirclez:
    While working on the Comet WITH the bungie cables connected, the prop bar snapped off. The issue isn't the prop bar, it is the weak single screw that holds on the prop bar, that, and the fact the PF doesn't stay straight in place (wants to lean to one side). If the screw is old and even slightly oxidized, it is probably not going to be able to withstand the weight of the PF. I connect a bungie to any good place I can find on the front of the PF and I hook the bungie onto the back box on something metal (usually take the back glass off and stick it on something inside the BB.
    #45 8 years ago
    Hmm, a bungee might not be a bad idea. Probably easier using common items on hand.
    I agree on the prop screw, and did inspect mine while questioning just why Williams left servicing to such a flimsy mechanism. I felt much more comfortable with my PVC tube in place: one end resting solidly square (flat) on the cab bottom, and the other end hooked into a convenient sturdy bracket on the pf. Not perfect on its own, but helps level and balance the pf and share the load with the stock prop.
    #46 8 years ago
    You really need to clean your playfield.. You have weeds growing out of your outhole.
    #47 8 years ago
    Stern shoulda tried harder.
    #48 8 years ago
    Am I missing something here? Why not take the balls out and tilt the pf all the way up and lean it against the bb so it's at an angle like this.
    Sure the newer Sterns have a stop at the end of the rails but on an older game you could make your own.
    #49 8 years ago
    Quoted from MustangPaul:
    That makes it a little hard to work on the lower flippers
    #50 8 years ago
    Not at all, just stand on a stool off to the side, done it many times.
    This page was printed from https://pinside.com/pinball/forum/topic/stern-almost-killed-me and we tried optimising it for printing. Some page elements may have been deliberately hidden.
