(Topic ID: 146728)
Stern Ali - Feature lamps blowing fuse?
By noiseprisoner
8 years ago
  • 1 post
  • 1 Pinsider participating
  • Ali Stern Electronics, 1980
#1 8 years ago
I'm pretty new to this hobby and soaking up as much info as I can. I acquired a pretty worn out non-working Stern Ali from a coworker and was able to get it running great by replacing the rectifier board and rewiring the J1, J2, J3 connectors. The playfield was totally shot and I recently purchased a fantastic NOS playfield from a fellow Pinside member. I read up on everything I could find regarding playfield swaps and spent most of 2 days working carefully on moving everything to the new playfield, replacing a couple worn items in the process. Now, I'm finished but the 1st fuse on the rectifier board (10A on the far left) blows when I power the machine on. Sounds are working, solenoids are working, and GI lighting seems to be working, but the feature/insert lighting is dead, pic is attached. I've gone over the wiring very carefully under the playfield several times now and cannot seem to find the culprit. If I remove the J1 (playfield) connector from the rectifier board and power the machine on, the fuse does not blow. It has to be something I did when swapping the playfield wiring but I'm just not seeing it. If I understand correctly, does the bare braided wire carry the current and the other connection to the board trigger the ground? Like I said, I'm new to the hobby so go easy on me. It worked great before the playfield swap so I'm sure it's something simple that I did wrong...my eyes are blurry after looking at these wires for so many hours. Thanks in advance for any suggestions!
Boston, MA
$ 12.00
$ 12.00
Third Coast Pinball
$ 3.00
Cabinet Parts
20eyes
$ 69.00
This page was printed from https://pinside.com/pinball/forum/topic/stern-ali-feature-lamps-blowing-fuse and we tried optimising it for printing. Some page elements may have been deliberately hidden.
