(Topic ID: 242970)
Stern 1982 Iron Maiden
By chad
9 days ago
  • 25 posts
  • 8 Pinsiders participating
  • Latest reply 5 days ago by HHaase
There have been 7 images uploaded to this topic. (View topic image gallery).
IM-100-001.pdf (PDF preview)
#1 9 days ago
Looking for info on the board that controls the strobe? Lamp in the back box. In need of one. The manual has no description. (Appears manual is incomplete?) Thank you
#3 9 days ago
Already did. Thanks!
#5 9 days ago
Ok , will give it a try. Thank you.
#6 9 days ago
Here's pictures of the one in my game. Is that all you need?
John
#7 9 days ago
Quoted from Dayhuff:
John
Thanks John. Now I just need to located one of these boards.
#8 8 days ago
I think it's a rip off of a solenoid expander board that runs a single flasher bulb. Could very likely just use one of those (Bally or Gottlieb) but you may have to investigate the circuit and also make a plug adaptation.
#9 8 days ago
Cool thank you
#10 8 days ago
LOL knowing Stern in 1982, I'm sure there's an exact schematic in a Bally or Gottlieb game of the era.
Other than Flash Gordon, what games used strobes like those?
#11 8 days ago
Flash Gordon is the only one I can think of.
#12 8 days ago
Same here, it's the only other one I know of, but the Flash Gordon schematic doesn't look anything like the Iron Maiden board.
So it may actually be a unique design to this machine.
#13 8 days ago
Quoted from HHaase:
Right. You have a much better chance of incorporating a Bally or Gottlieb sol. driver expansion board to drive that single flasher.
#14 8 days ago
Well, I’m trying to build an Iron Maiden using an f2k as a base, so this info is super helpful
#15 8 days ago
One of the favorites in my collection, I must say.
#16 8 days ago
Get me some good hi-res photos of both sides of the board, and I’ll probably ask for some part numbers, I can build new ones ..... assuming whatever is behind that heat sink isn’t really odd.
#17 7 days ago
Here's more pictures, certainly not hi-res but its the best I can do.
John
#18 7 days ago
Those will do quite nicely!
Any chance you can read any markings on CR1, Cr2, C1, C2 and C4?
That’ll let me get a schematic made up. Then I think just hole size and spacing would be all else I’d need.
#19 7 days ago
I’m in for one!
#20 7 days ago
Quoted from HHaase:
CR1 has 4004 on it.
Nothing on CR2.
Nothing on C1.
C2 has 1K100 on it.
C4 has ECI 474K 100V on it.
Hole size in the corners is 1/8th inch. The board measures 2 1/2" x 3 1/2".
John
#21 7 days ago
Awesome, Thanks for posting John!!
#22 5 days ago
May take a bit, but already working on building the schematic for this one.
Looks like there's zero reference out there on this board, so I'll also work on adding it to PinWiki.
John, mind if I use your photos for that?
-Hans
#23 5 days ago
Not at all, knock your self out.
John
#24 5 days ago
Much appreciated!
Just need to clean it up a bit, but schematic is done, and I'll probably stick with thru-hole for this one as I don't see me making it in big numbers.
So I can work on the actual board layout too. Bill of material may take a bit.
-Hans
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 399.95
$ 14.50
PinballElectronics.com
$ 7,499.00
Flip N Out Pinball
$ 55.00
Pinball Photos
$ 50.00
$ 55.00
Pinball Photos
Third Coast Pinball
Displays
PinballSolutions.eu
