(Topic ID: 246598)
Gottlieb Airport - Stepper alignment, Relays overheating.
By Murph66
47 days ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 6 days ago by Murph66
There have been 10 images uploaded to this topic. (View topic image gallery).
#1 47 days ago
I’m new here and I have a Gottlieb Airport EM 2 player machine. I can’t find anywhere a photo or diagram of the alignment of the 0-9 stepper or the Ball stepper. Currently the machine plays 2 player 1 to 5 balls but will not trigger game over.
In addition the Ones counter unit, ones point relay (N relay), and the 1st player scoring relay (J Relay) And are engaged and get incredibility hot.
Please help.
Mike
167FBF82-F983-4EB6-9550-D5D5B31E79B0 (resized).jpeg6E562E06-E3D7-40CF-AF09-2A4CFA05E63E (resized).jpegBE7A7A21-9E56-433C-936A-32E4F62A9240 (resized).jpegC96A0E22-E13C-4E3F-B731-8E34765C3E83 (resized).jpeg
#2 47 days ago
the 1 point relay stuck on, if you put a new set of rubbers on it most likely you have a pf contact gaped too close.
as to the 0-9 stepper there is no home position. Alignment is ensuring the shoes are lined up with the rivets.
I cant remember if airport has a "player unit" that normally does "game over"
#3 46 days ago
I will check that out! Thank you so much.
#4 46 days ago
Pinhead do you know or have pictures of the Ball Counter Stepper alignment? Some on else has worked on this machine previously and I am not confident that the Ball count stepper is correct.
86719F6D-8EAE-4621-A782-49CD6FB1CFFF (resized).jpegD2544073-1E9A-4678-88A6-A590A4767BCF (resized).jpegF1925430-1A6A-4DE5-B65A-67991E59307A (resized).jpeg
#5 45 days ago
When the Ball Count unit is reset, it's in a position that the schematic calls position 0. In positions 0,2,4,6 & 8, the 1st Player Scoring Control (AA) relay should be energized. In positions 1,3,5,7 & 9, the 2nd Player Scoring Control (BX) relay should be energized. Also, in later positions as shown on the schematic, the Last Ball (XB) relay should energize.
#6 45 days ago
Thank you HowardR. Much appreciated.
1 month later
#7 9 days ago
Update on this issue: the problems were: 1) The player one One’s score reel solenoid burned and open. 2) Misadjusted switches in most of the score reels. 3) Score reels gummy and needed rebuilt.
I am waiting for the solenoid to arrive, however I pulled out some way old school moves and connected a 100watt lightbulb in place of the Solenoid and the unit plays great. The system resets and after final alignment of the player unit plays. The exception is the last ball and game over not operating correctly because of the missing solenoid / reel switch night t reassessmbled yet.
05B1E5E3-1798-4C54-9FD7-8DDBEA46BEFA (resized).jpegCC2DB336-296A-47DC-92F7-E82F3A18B1EC (resized).jpeg
#8 9 days ago
Your second photo of the 0-9 unit has a wire missing. Those two shoes should be wired together like the others on that stepper.
#9 6 days ago
Thank you Darcy good catch. Will check that out in the morning.
In the meantime the ones solenoid has been replaced and reel unit rebuilt and work great. The ones, tens, hundreds, thousands relays and reels operate perfect for player 1 and player 2.
However next issue is that the Ball counter stays on player one. The player solenoid on the player unit kicks to advance but the reset solenoid also kicks and the net result is that it will not advance. If I manually plunge the solenoid by hand it advances fine.
Additionally it seems that the last ball relay, and game over relay do not trigger at all.
$ 69.99
$ 49.00
$ 29.04
Playfield - Plastics
F14 Tomcat Slingshots Out of stock
Pinball-Mods.com
$ 299.00
Lee's Parts
$ 229.00
Tilttopper
$ 49.99
$ 40.00
Great American Pinball
G-Money Mods
$ 29.95
Pinball Photos
$ 94.95
$ 24.00
$ 269.00
$ 22.00
Hardware
The MOD Couple
$ 59.95
pinballmod
$ 14.00
$ 29.95
Pinball Photos
$ 27.99
$ 269.00
Displays
Boston Pinball Company
