(Topic ID: 259570)
Start button score points for Player 1 + MPU lock up - SORCERER
By FatPanda
10 days ago
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 2 days ago by FatPanda
#1 10 days ago
I had crossed 2 sets of connectors late last year. For those that aren't familiar with WMS games of this era, there are a set of white and black connectors, and I put a black one with a white one and killed my MPU. I had the board repaired by Jerry Clause (great guy btw) and the game has been running mostly good for the last 2 months. The one thing that happens when starting multiple player games is that every time I press the Start button to add players, it also adds points to Player 1's score. It will do this even after 4 players are added. I couldn't tell you the exact value, and the value seems like a random amount (not always 5K or whatever).
The other issue I sometimes see is that in attract mode or sometimes (more rarely) in the middle of a game, the game will lock up. Everything but the GI shuts off. On the diagnostic LED on the MPU, it shows error code 7. I can press the sound test button on the MPU and it'll make a sound, afterwards I'll press the other diagnostic button, and it'll change to error code 5. Then a quick shut off and back on and the game will boot back into attract mode. This has been happening after the MPU repair.
Thoughts on either issue would be appreciated!
#2 10 days ago
In switch test does the start button work single or multiple switch fires. ?
#3 10 days ago
Quoted from chad:
I'll have to check. TBH, not familiar with how switch test works in these games. Time to bust out the good ol' manual
#4 9 days ago
When I put it in switch test, it constantly shows that switch 29 and 30 are activating, which I assume shouldn't be the case?
Switch 29 is Ramp 1 and Switch 30 is Ramp 2. I assume those are the lock switches. During a regular game, these switches function properly.
#5 9 days ago
Anything touching on those 2 switches, bent over diode shorting across itself. Wired correctly.
#6 9 days ago
Quoted from chad:
I didn't take off the glass yesterday but will check. If they were constantly triggering, wouldn't i see the impacts during gameplay?
#7 9 days ago
Go into switch test and hold the start button in. Wms switch test will show all closed switches one after the other.
What's the score added that might help you might the error as well.... is it always the same?
Also, ramp 1 and ramp 2 refer to the ball trough.... did you leave the balls in when you did switch test?
#8 9 days ago
Quoted from slochar:
Ramp 1 and 2 in the trough makes sense, and yes, the balls were in when I started the switch test
So with the balls out, I should expect no closed switches right?
I had started a game and added players, and the drop target bank would behave as though one of the drops were hit, it would time out, then reset whenever I hit the start button. I'll keep that in mind as I'm diagnosing.
#9 9 days ago
Correct no switch closures.
#10 5 days ago
Found the problem! At some point there was a credit button installed (I dont know why since there is free play!) But one of the coin switch wires was wrapped around this bracket and was pinched, causing a short messing up the entire row. The switch test eventually led me to this. Thanks guys!
#11 2 days ago
So going back to the original post, any thoughts on what is causing the MPU to lock up and why I have to go through the little "restart" procedure that I need to go through?
$ 14.50
PinballElectronics.com
$ 21.00
2,000 (OBO)
Meriden, CT
$ 17.00
$ 689.00
$ 99.00
Pinball Sales
2,300
Denver, CO
Filament Printing
$ 29.95
Pinball Photos
€ 9.10
$ 16.95
