Hi,
Suddenly my Starship Troopers is without any sound at all?
I have checkef all fuses in the backbox, and all cables seem to be fine...any sugesstions?
Brian
Copenhagen
Hi,
Brian
Copenhagen
Hi,
It could be your RAM in U4. I had a similar issue on my A13 and changing the RAM fixed it. It also fixed the problem for a fellow pinsider so it's worth a try
Jack
https://pinside.com/pinball/forum/topic/goldeneye-no-sound#post-2972307
Tried to replace U7 and U4. (U7 new) ( U4 the same).
Still no sound???
Do I need a new U4? ( If do where can I purchase this in Europe?)
Any other suggestions?
Brian
Hi Brian,
I would definitely try a new U4 as these chips are relatively cheap. Check the number on your chip and get the same thing from pinball center. The spec for the CPU/Sound Board says 6116 RAM part number 105-0052-05.
http://www.pinball.center/en/shop/electronics-parts/ic/1233/ic-6116-ram
Good luck,
Jack
Still no sound.
When we check the Sound reset point on the board it is "Low"...the same test on Lost world is high - and when we swoap the boards the "lost world" board is working in Starship Troopers, and the "Starship" board is then not working in the lost world game..,
Any suggestion?
