(Topic ID: 266590)
Starship Troopers Multi Ball auto Launch issues
By RaoulJuke
77 days ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 76 days ago by chuckwurt
#1 77 days ago
Recently picked up a SST;s in a bulk lot and got to say, very fun game. Unfortunately i am having issues with the ball launching into play tho. I've managed to fix it to be ok when i launch using the plunger, but when multiball happens, or any time the aut launch coild mech is required, 7/10 times the ball launches with nt enough power to kick the ball into the upper part of the playfield and into play -so the ball ends up drainging immediately on the far right drain. Super annoying
I have pulled the mech apart and cleaned the coil sleeve up a lot (did not quite have that size availabe). cleaned the mech, the coil, & used novus on playfield in the trough launch portion.I noticed that the U shaped kicker that comes up through the playfield was a bit out of shape, and done my best to re-shape it.
Anyone have any ideass what the issue is? Is it most likely still the U shaped kicker or another part of the mech slightly out of position? The arm on the kicker also seems a little loos so it sits a bit off centre. anyone experienced this before and what was it they tweaked to get it right?
#2 77 days ago
Quoted from RaoulJuke:
Does it hit the ball square, a good blow ? Or one sided a glancing blow ?
You might have to try and watch it kick, the coil firing might be different than at rest or pulling the mech with your finger.
#3 76 days ago
Quoted from LTG:
Cheers, i am thinking its something along those lines as after some readjustment ive gotten a bit more consistency, but once i get one go bad, i get a couple in a row.
If someone has a SST thats fires perfectly it
Would be a great help if the could post a couple of photos of the underneath & from behind of the launcher mech so i had something to compare it to
#4 76 days ago
This was a few years ago so I'm going off memory here. When I got my sst, one ball would not launch good, and then the other balls would hit it and they would all drain. The pivot point of the ball launch arm was really worn, and when I replaced that it fixed the problem.
#5 76 days ago
I would rebuild the entire ball launch mech. The SST I had this mech was really messed up. As you know it’s critical this mech works well on this game. Rebuild mech and make sure the bracket that attaches it to the playfield isn’t broken too.
$ 99.00
Arcade Upkeep
$ 54.99
$ 65.00
Lighting - Backbox
Arcade Upkeep
Trade
Machine - For Trade
Boonville, IN
$ 54.99
Gweem's Mods
PinSound
$ 1,000.00
$ 999.00
$ 36.99
Lee's Parts
