(Topic ID: 261801)
Stars MPU won't boot with PF lamp connectors plugged in
By QuietEarp
  • 15 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by QuietEarp
  • Stars Stern Electronics, 1978
#1 4 years ago
Hi,
I was doing some work on my Stars. I had it playing well for a few weeks. Then it wasn't getting 12 volts DC on the rectifier board (TP3). I corrected that issue (Bridge Rectifier) and now the game will not boot up. It gave me 4 flashes. I found that if I unplugged J1 on the MPU the game would boot. J1 feeds the lamp driver board and displays.
I find that if I connect J1 on the MPU but unplug connectors J1 and J3 on the lamp driver which feed the insert lights on the playfield, the game boots up. If either of these are connected to the lamp driver board, I only get 4 flashes on the MPU.
Where should I be looking from here? What is causing this?
I have a Weebly MPU and the rest is vintage.
#2 4 years ago
An update. I swapped in the Lamp Driver Board from my Mata Hari and the game worked fine.
Stars LDB in Mata Hari works fine.
So I swap the boards back to their original games and everything in Stars works fine?!
What could this mean? Repin board and connectors J1 and J3? Seems weird that these connectors would cause booting problems as they only drive the controlled lamps?
I would still like to know why that happened because I didn't like that and it could happen again. Any ideas?
#3 4 years ago
The MPU board 6821 PIA chips can be determined as "faulty" during the power on self test if one of their port A pins are shorted to ground or something else.
U10 port A controls the switch matrix, lamp board and display numbers.
U11 port A controls the display digits.
All the lamp and display signals go through MPU J1.
If by chance when you were diagnosing your 12 volt issue did you disconnect J4 from the lamp driver board and accidentally reinstall it off by one pin or upside down?
The only way I can see J1 and/or J3 from the lamp driver board to cause this issue is if there's a shorted lamp socket to a switch on the playfield - but even that's a bit dubious.
Quoted from QuietEarp:
Don't reterminate your connectors for this issue. The error condition was a short circuit, not open circuit.
#4 4 years ago
Quoted from Quench:
I don't see how I could have as it has the key in the connector housing.
Thanks for the suggestion though!
#5 4 years ago
Update!
When I did the whole board swap thing between Mata Hari and Stars I did not fasten the board with the screw so the boards were floating.
Game works fine with lamp driver board floating. When I screw the lamp board in creating a solid grounding path with all lamp board connectors plugged in the game does not boot.
If the board is screwed in and the connectors to the PF lamps are unplugged (J1 and J3) the game does boot up.
Any thoughts with this new info?
#6 4 years ago
Which one is it? J1 or J3?
Does disconnecting J2 and J3 (playfield and cabinet switch matrix harness respectively) from the MPU board make any difference?
Do you have the earth braid at the base of the head connected to the cabinet earth?
#7 4 years ago
If J1 or J3 is plugged in the game does not get past 4 flashes. Both must be unplugged for game to boot.
Disconnecting MPU connectors J2 and J3 does not make any difference. I also tried only disconnecting one of them at a time and there was no difference.
Earth Braid is connected to cabinet.
#8 4 years ago
What happens when:
(a) When the lamp driver board is not screwed down, are all feature lamps on the playfield working properly?
(b) Everything is connected but you don't screw the lamp board, how much voltage do you measure between the grounded metal shield in the head and the GND test point on the lamp driver board?
(c) At the lamp driver board with J1 and J3 connected and screwed down but disconnect J4 from the lamp board?
(d) All four connectors are connected to the lamp board and screwed down but you disconnect all other playfield connectors (i.e. MPU-J2, SDB-J1, SDB-J5, Rectifier board-J1)
(e) All 5 displays are disconnected
#9 4 years ago
Quench, thank you for your help! I have seen you in these types of threads diagnosing things and the help you provide is very much appreciated.
Now the game seems to not boot when the grounding screw is in the lamp board no matter if J1 or J3 is plugged in on the lamp board. This was definitely different yesterday.
a) yes, all feature lamps work properly when lamp board is not screwed down
b) 0 volts
c) Game boots
d) 4 flashes on MPU
e) 4 flashes on MPU
#10 4 years ago
Ok, two more if you don't mind. What happens when:
(f) Everything's connected and screwed down, but disconnect J2 from the lamp driver board (LDB)
(g) Everything's connected and screwed down, but disconnect J4 from the solenoid driver board (SDB)
Can you retry (b) from above but take measurement in both AC and DC voltage?
If possible please post a clear picture of the J1 connector at the MPU board clearly showing all wire colors and same with J4 at the lamp driver board.
#11 4 years ago
(F) 4 flashes only
(G) 4 flashes only
(B) 0 volts AC and 0 volts DC
IMG_5701 (resized).jpgIMG_5701 (resized).jpgIMG_5702 (resized).jpgIMG_5702 (resized).jpg
#12 4 years ago
That second picture showing J4 on the lamp driver board, you can see nine red resistors on the board.
With the machine OFF, and your multi-meter set on resistance mode, black meter lead connected to ground, how much resistance do you measure with the red meter lead on the left side leg of each of those nine resistors?
#13 4 years ago
About 3230 ohms on each of them. One (R75) tested at 4300 ohms. Measured to the ground test point on the LDB.
#14 4 years ago
Readings are good.
Can you please clarify this, are you counting the initial power on flicker as a flash?
Can you post a clear picture of the J1 connector at the MPU board showing the wire colors, and also a general picture of the MPU board.
Since this started at the time you repaired the rectifier board, what else did you touch at that time?
Long shot, is there something behind the lamp driver board that's shorting?
If you put the Mata Hari MPU board in this game and disconnect J4 from the solenoid driver board so wrong solenoids don't activate/lock on, what happens?
#15 4 years ago
So I have been playing Stars without the LDB screwed in and it has been fine. Today I was going to try all the new recommendations so I screwed the screw back in grounding the LDB and the game booted fine. I will post again if this starts to reoccur.
I will post some answers to your questions though because for all I know this will start happening again!
I do not believe I am counting any initial flicker as a flash.
I didn't work on anything else besides the rectifier board at that time though I got the machine un functioning and it has only had about 60 games on it since I got it going.
No short behind LDB.
IMG_5717 (resized).jpgIMG_5717 (resized).jpgIMG_5718 (resized).jpgIMG_5718 (resized).jpg
$ 29.00
RoyGBev Pinball
Troxel Repair
$ 169.00
$ 29.00
RoyGBev Pinball
St. Louis, MO
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/stars-mpu-won-t-boot-with-pf-lamp-connectors-plugged-in and we tried optimising it for printing. Some page elements may have been deliberately hidden.
