(Topic ID: 269461)
PnP Pinball - Beverly Hills Cop - homebrew
By MeesterPieter
1 year ago
  • 162 posts
  • 15 Pinsiders participating
  • Latest reply 3 days ago by MeesterPieter
  • Topic is favorited by 23 Pinsiders
There are 162 posts in this topic. You are on page 3 of 4.
#101 7 months ago
i felt there was something missing in the bottom right so i made a hole for a scoop there earlier.
while testfitting the scoop i thought it might be nice to combine it with the left kickout.
so i made a 3d printed subway that i can mount under the kickout hole.
for those interested, i made the subway out of 2 pieces and welded them together with a 3d pen:
i only welded it (and sanded ) on the outside so the inside stays nice and smooth
2021-09-27 16.25.25 (resized).jpg2021-09-27 16.40.59 (resized).jpg2021-09-27 16.41.05 (resized).jpg
#102 7 months ago
the guide is ready for all the inserts, now i can proceed with routing the rest of the inserts
#103 7 months ago
finalized the insert layout and routed all holes for the first time, next time i'll be drilling the holes through to create an edge
starting to look like a real playfield now
#104 7 months ago
also welded the subway from both sides just to make sure its strong enough, did have to sand it afterwards
#105 7 months ago
wow your playfield cuts look really clean
#106 7 months ago
Thanks, most fit quite well indeed, happy with the guide i made. now just routing them all again with the smaller shank, hopefully without to much errors
#107 7 months ago
for the next step im first drilling holes everywhere because im using a smaller shank
#108 7 months ago
im using a small file with a flat bottom to clear the edges of the holes so the insert will be nice and flat
the rest of the holes are ready, made a few mistakes but since ive made a 100+ routings thats not that bad.
the bigges mistake was the guide coming loose, luckily i have been able to fix that by using a large square insert instead of the rectangular one i had planned.
for the rest of the mistakes a little filler or epoxy will be fine.
next up printing some more inserts and glue them in place
#111 7 months ago
glued in the first insert, this one needed some filling with epoxy because the guide slipped, so i glued the insert in with epoxy as well, worked nicely
#112 7 months ago
since the epoxy worked nicely as glue, why not try the rest with epoxy as well, makes it a little bit easier to close most gaps as well
first test fitting all the inserts and numbering them and also marking orientation
fixing the epoxy with UV light
first batch fitted, next up sanding them flat (while printing some more inserts )
2021-10-22 10.17.04 (resized).jpg2021-10-22 10.17.19 (resized).jpg2021-10-22 10.17.24 (resized).jpg2021-10-22 10.17.30 (resized).jpg
#113 6 months ago
getting all the inserts in and starting with sanding
2021-10-23 09.08.08 (resized).jpg2021-10-22 17.14.29 (resized).jpg2021-10-22 17.14.33 (resized).jpg
Almost ready sanding, the inserts are flush with the playfield, all large gaps filled.
now i just need to fill the last tiny gaps
2021-10-26 17.28.18 (resized).jpg2021-10-28 10.12.43 (resized).jpg2021-10-28 10.12.59 (resized).jpg2021-10-28 10.13.09 (resized).jpg2021-10-28 10.13.15 (resized).jpg2021-10-28 10.13.25 (resized).jpg2021-10-28 10.13.43 (resized).jpg
#115 6 months ago
coated the front and the back twice, now back to assembly
2021-10-31 13.55.47 (resized).jpg2021-11-01 09.22.46 (resized).jpg2021-11-01 09.23.01 (resized).jpg2021-11-01 11.29.24 (resized).jpg
#116 6 months ago
reassembling the playfield
the targets on the left are being replaced with droptargets
assembled the subway and scoop. i had to modify the assemblies a bit so they would fit.
the subway goes under the playfield where some of the inserts are at, i'll have to make some changes to the subway later to make some room to fit the LED's there. and i also need to make a switch near the entrance to register the ball entering of that side.
2021-11-04 16.04.13 (resized).jpg2021-11-05 10.13.27 (resized).jpg2021-11-05 10.13.20 (resized).jpg2021-11-05 09.56.58 (resized).jpg2021-11-05 09.56.47 (resized).jpg2021-11-05 09.32.50 (resized).jpg
it does all fit after some modifications, but next time i'd better keep a little more room for all the assemblies when designing
#117 6 months ago
Looks really cool, a lot of drop targets! Love drop targets
#118 6 months ago
Yeah the more the better
#119 6 months ago
Quoted from MeesterPieter:
Absolutely, hm i want more too now, have to take a look, if i can fit some instead of my standup targets as well. Hihi
#120 6 months ago
2021-11-12 16.12.19 (resized).jpgalmost everything back together
mounting a lot of new sensors, just need to make a sensor on my 3d printed subway and another 1 or 2 in the ballthrough.
dismantled the old arduino wiring so i can use that to connect my cobrapin controller
i have an autokicker but since i'll have to line that up with the plunger and also need to make some cuts in the playfield i'll leave that for now, maybe i'll add it later if i miss it.
next up adding the lights where i can, modyfying the subway so i can fit some lights above it and wiring up all switches
3 months later
#121 3 months ago
Been a while since the last update, not much progress lately.
I had already made some simple setup in MPF, last week i've been testing with setting up the cobrapin and a single solenoid and switch.
now that i got that working i can get some more configuration done and start wiring the complete playfield to the cobrapin.
I've also settled on the theme as some of you may notice
#122 71 days ago
first time hooking the cobrapin with mpf up to the actual playfield
next to do a lot of wiring and connecting to get everything working
#124 70 days ago
thanks, starting to get somewhere
#125 69 days ago
everything which i already had wired is now connected, most of it already working.
next ill need another afternoon to solder the rest of the switches and coils
#126 64 days ago
soldered the rest of the switches
2022-03-18 11.36.12 (resized).jpg2022-03-18 13.18.21 (resized).jpg2022-03-18 13.33.51 (resized).jpg
#127 64 days ago
Huge SG1/SGA fan here. Love seeing the progress on this. Can't wait to see how it all comes together in the end! Any hints as to artwork yet?
#128 64 days ago
Quoted from Miguel351:
We'll, i decided to keep to the playfield layout mostly like the original data east playfield for this first build. And i just didn't had the feel with the stargate theme for this layout. I do have another playfield laying around to be the basis for a more complex second, stargate themed, playfield. so still planning to make a second stargate themed playfield, but not this one.
as for this one, i have decided to go with beverly hills cop
#129 64 days ago
That is a cool idea too! Love it
#130 64 days ago
One of the current sketch idea's of the playfield art.
I have made the inserts in the playfield matching up with the tower of the police station so i can add modes etc on there, and axel as ballsaver
also been ripping some sounds and vocals from the movie to use as callouts in the game.
but first i'll be focussing now on getting the playfield working well with MPF, adding the insert lighting, and then to create some game modes.
will be a while before i go further into the artwork.
I've also sketched some artwork for the cabinet, but nothing i'm really happy with yet.
Any ideas or sketches for the artwork side is always helpfull though
#131 64 days ago
Maybe the orange black palmtree background from the beverly hills cop 2 cover art will look good on the sides
#132 64 days ago
i've looked at that art to use for the playfield but hadn't thought about it for the cabinet, schould be doable to remake something like it in high resolution indeed
#133 60 days ago
more wiring
2022-03-22 16.13.34 (resized).jpg2022-03-22 16.13.45 (resized).jpg2022-03-22 16.13.49 (resized).jpg2022-03-22 16.19.01 (resized).jpg
#134 58 days ago
testing some brackets for my new WS2812 leds i got from china
i wanted something i could easily make onto a printed bracket and which can fit connectors onto.
these looked nice and cheap
2022-03-25 14.45.27 (resized).jpg2022-03-25 15.37.59 (resized).jpg2022-03-25 15.39.45 (resized).jpg2022-03-25 15.55.28 (resized).jpg2022-03-25 15.55.39 (resized).jpg
#135 44 days ago
first one works, now to add some more coding while i wait for more parts
#136 41 days ago
Most mechanical stuff is now connected and seems to be working.
The programming in MPF is still very basic, direct switch responses and simple scoring/music
still need to sort out some issues and adding some more posts/rubbers etc
after that i can focus more on the lighting and game design
#137 41 days ago
Needs some sort of "banana in a tailpipe" target to hit
#138 41 days ago
Quoted from toyotaboy:
Needs some sort of "banana in a tailpipe" target to hit[quoted image]
Indeed it does!
i've already added some small round inserts at different targets for some sort of banana mode, something like hit the target with the lit banana or something!
haven't thought it out much more than that though. but the banana in the tailpipe and "anti banana disguise" scenes will definitly be used for something there!
thanks for the input, keep it coming!
#139 41 days ago
Indeed it does!
what if the orbit shot has a 2 trailer semi truck that weaves in a wave pattern that you have to time your shot.. perfect for the pointer sisters - neutron dance track im sure you're going to include
#140 40 days ago
what if the orbit shot has a 3 trailer semi truck that weaves in a wave pattern that you have to time your shot.. perfect for the pointer sisters - neutron dance track im sure you're going to include
I've thought about doing something with the truck for some sort of mode , i do like the idea of a truck going left and right , something to think about.
i've already checked but couldn't really find a suitable scale model truck yet.
Maybe something to look into or just get something the right size and 3d print a similar grille and paint it
for making some moving things i have some 5v 28BYJ stepper motors, so as long as its something thats not made to be hit by a ball i can try to make it move a bit
#141 40 days ago
i can help model that if you really want to make that mech. so long as you attach a metal grill to the front it should hold up fine (which i can also help with)
#142 39 days ago
If you want make a simple sketch of what you have in mind
#143 39 days ago
added some more posts and rubbers:
2022-04-08 16.34.05 (resized).jpg2022-04-08 16.33.58 (resized).jpg2022-04-08 15.42.25 (resized).jpg
#144 37 days ago
to make sure i dont short out the leds when connecting the wiring by switching the input and output ive used different connectors for in and out, better safe than sorry
2022-04-12 10.49.30 (resized).jpg2022-04-12 12.32.51 (resized).jpg2022-04-12 12.32.57 (resized).jpg2022-04-12 12.37.41 (resized).jpg
#145 36 days ago
Have a rough model, took a guess on scale. If you give me a boundry box I can make adjustments before getting too far.
#146 36 days ago
Thanks for thinking along, and for working on a model
I'm still a few steps back though , what kind of location/mechanism did you have in mind?
#147 36 days ago
Figured 4 linear rails recessed into the playfield, and then linear actuators that push each section to create the snake motion. Servos might work with a big enough arm. Coils might be overkill (and suck a lot of juice for one mech)
$7 for each 100mm linear rail
https://www.aliexpress.com/item/1005004052262450.html?spm=a2g0o.productlist.0.0.bc186351NV6Dyc&algo_pvid=a72a2f81-0520-4185-b7a2-b4a7b214f0b0&algo_exp_id=a72a2f81-0520-4185-b7a2-b4a7b214f0b0-1&pdp_ext_f=%7B%22sku_id%22%3A%2212000027870640222%22%7D&pdp_pi=-1%3B7.36%3B-1%3B-1%40salePrice%3BUSD%3Bsearch-mainSearch
#148 35 days ago
I like the slides for that motion idea, i was thinking more of something like that truck going over the entrance of the ramp shot or something for a multiball lock or something, but i'll keep it in mind for now
#149 27 days ago
earlier on i already scanned the playfield, thought that would be handy for photoshopping.
but it makes it also easier to map out the location of the inserts for the light shows
#150 22 days ago
always nice to compare the autocad drawing and the actual thing i've made
Metal-Mods
$ 93.00
ArcadeMade
Filament Printing
YouBentMyWookie
$ 18.95
