I’m having trouble with the sarcophagus drop/rollover target popping up before you even launch the ball. It’s popping up and continues resetting over and over once I start a game. It doesn’t always do it right away, but sometimes it just pops up right after launch. Also I can hear a clicking under the playfield at times. Like something else going off randomly when I’m playing, at times when nothing is suppose to be happening.
I’ve read in another post that the drop target popped up early, and I believe it was the left ramp optic causing it for that guy. Not sure if this is the same issue.
It seems to drop and reset no problem in self tests. I cleaned the optics with a q tip, only so far. I did have an issue when I first bought it, with the right ramp optic. It wasn’t registering the Stargate letter shots. I had to add solder to connect where it was burned out. Maybe that’s causing a problem? It has worked for over a year without any problems though. Anywho. I contacted PBR and asked in the Stargate owner forum. Love to solve this ASAP if anyone had any idea. Thanks everyone in advance!
