Got a couple things I need help with...
The rear left VUK was working fine & all the sudden got stuck in the up position, the coil overheated & caused the sleeve to melt...so I need to replace the coil & sleeve but what is causing it to fire & stay in the up position? Transistor blown? If so, which one?
Also, left outlane diverter isn't always firing when it should...I see there's an opto transmit/receive on the left wireform that leads to the outlane...is that most likely the issue of why it's not firing...anything else cause that to fire?
Also, curious if SG takes the standard Gottlieb 31" legs? Anybody have Sega 30.5" legs installed...assuming the 1/2" wouldn't make a difference.
