Anyone have a Stern Star Wars rulesheet yet?
Quoted from Butch2099:Do the rules typically change with code updates?
well, not typically...
the "tree" is there, its how D. have seen/feel it from an overal view
than updates will of course correct bugs, and also make better some parts of the games, but to reply to your ask, no, not typically
certain rules do change with newer code and will change as with most games. there is also an add a ball not mentioned so far and a few other things. I assume many rule changes will come, as did with gb, got, twd. twd had many extensive rule changes per code updates. blood bath wasnt even written in the first few codes. and the first few codes you could stack well walker and barn multi ball, it was removed later.
That's what I thought. I was surprised anyone would have a rule sheet on the game at so new with so much code yet to come. Hopefully anyway
Quoted from eliottk:rules of the new Star Wars pinball.
Thanks for putting this together. Good run through of the rules as-is.
Really enjoying the game so far, needs more VO and callouts to figure out the flow/rules during game.
Quoted from fosaisu:Bump, any chance this will be updated to reflect the current, virtually complete code?
The tilt forums rulesheet is a wiki so anyone can go edit it.
I don't see an answer to this in the rulesheet. What does completing the four rebel alliance switches on the 2 inlanes and 2 outlanes give you? They light up and can be toggled with the flippers, I believe. Thanks
If you light up all inlanes and outlanes about 4 times you activate the Hyperspace Hurry-up shot arrows at the Left Orbit and Right Ramp.
Quoted from jlatko:I don't see an answer to this in the rulesheet. What does completing the four rebel alliance switches on the 2 inlanes and 2 outlanes give you? They light up and can be toggled with the flippers, I believe. Thanks
Those are the shots that get the multiplier. There are 3 of them lit at first, but the higher the multiplier, the fewer there are until you get to 1. If they are red, you can move them with the flipper buttons and when green they are "enabled". You use the fire button to switch between red/green, and you can also move them around between balls with the left flipper.
It's one of (if not *the*) the most important mechanics of the game.
EDIT: R2-D2s special ability is that the threshhold for when the multiplier lights drop down to 2 and 1 is raised higher, enabling a bit more flexibility in how they are placed.
Quoted from ktownhero:Those are the shots that get the multiplier. There are 3 of them lit at first, but the higher the multiplier, the fewer there are until you get to 1. If they are red, you can move them with the flipper buttons and when green they are "enabled". You use the fire button to switch between red/green, and you can also move them around between balls with the left flipper.
No, not the movable shot multipliers, I know all about those. I'm talking about the 4 static lights above both inlanes and outlanes that can also be toggled with the flippers. Somebody mentioned above that lighting them enough times lights the hyperspace hurry-up at either outer orbit, which you then collect at the death star. Thanks for the info.
With a couple of minor edits, I managed to fit the wiki onto a 24" by 36" glossy poster. It only set me back $15 to print it at Walgreens, and I think it'll be a handy quick reference for friends when they play for the first time. If anyone wants the JPG, pm me
USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1573520687668 (resized).jpegQuoted from NathanH:With a couple of minor edits, I managed to fit the wiki onto a 24" by 36" glossy poster. It only set me back $15 to print it at Walgreens, and I think it'll be a handy quick reference for friends when they play for the first time. If anyone wants the JPG, pm me[quoted image]
What a great idea! I'd love the jpeg if you still have it around.
This page was printed from https://pinside.com/pinball/forum/topic/star-wars-rulesheet and we tried optimising it for printing. Some page elements may have been deliberately hidden.
