Quoted from tytydell:I recently bought a star wars pro (stern) and I popped the sd card out set it to read only and used a tool to back up the card to an image, I got a bit confused on weather I set it back to unlocked, I wasnt completely sure that it was unlocked but I was pretty sure, The game worked and saved vol. settings and freeplay on/off changes even after unplugging it for a while so I figured its probably set right, when I turned off the game and inserted a flash drive with the update code turned it back on it said please insert flash drive, after restarting it and removing the drive it works again, any recomendations on how to update it? are there any potential problems that would acurr if I was to flip the switch on the sd card and see if that fixes it?
I'm not sure how you mean by SD card. There are no cards or anything else that you need to take out of the machine.
It sounds like you have either a flash drive with wrong format, or your files are still zipped, maybe.
You want to make sure you download the updated code file from the Stern website onto your desktop (not the read-me file, which is there only to read the new and previous code updates). You will see the file folder contains 3 files. You want them all. Highlight that file folder on your desktop once downloaded and unzip or "extract" those files again on the desktop...all the above takes anywhere from 15 to 25 minutes. Once extracted/unzipped, drag the files into your flash drive. This again will take 10 or 15 minutes probably.
Make sure your flash drive is formatted FAT32 (similar appearing formats, like ExFAT, will not work). You can check this formatting ususally by clicking "properties" on the flash drive once it is in your computer. Note, the company PNY, which you can get at your local tech store or Best Buy come formatted this way...companies like SanDisk are not. Also note many folks, including myself have had issues downloading from Mac, and thus many including myself have had success with Windows computers.
Once the files are transferred, with the pinball machine off, place your flash drive into the recommended usb port behind the backglass and turn the pinball machine on...you will be prompted to update. There are a few options and likely all are fine, but I choose Full update and Yes to Verify. Best i can tell, Full vs. Quick is complete code revamp vs. Just the new changes and the verify is to analyze the flash and files for corruption or unnecessary files. Once finished, turn the pinball machine off and remove the flash drive. Thats it. Next time you turn it on, it will show you the new code is installed.
Note, a few folks, including myself encountered "fail to update" when in the process of the pinball updating...just try again, (the pinball machine screen usually takes you back to the initial screen asking if you want to update, full, verify, etc.)...just try again and it should work. For some on occasion, I noticed they needed to re-download from the website>desktop>flash drive a second time and that eventually worked as long as formatting was correct.
Once update is done, you will need to re-modify settings, i.e. free play, ball eject speed, etc..
Hope that helps. It's an awesome game! Seriously addictive!!!
