Quoted from Loganpinball:I came up with a different solution to wireform to ramp transitions working on Mandalorian 180 scoop. I will make another Star Wars designed set using this method. I figured out a way that the wireforms can lift the ball off playfield by itself if the spacing is correct and tapered. So another shot at this mod is coming up soon. This would involve a metal flap to cover the ramp cut out on the playfield with wireforms as the entry point. It works really well on Mandalorian. Heres pictures of the Mando scoop. The ramps will be the same design..
Here is a picture of the right ramp next to the scoop ramp. Hopefully you can see the idea better. A metal flap will be placed over the ramp cut out on wood and wireform ramp will be on top of that.
[quoted image][quoted image]
Very cool!
