Quoted from Giladla:Have solded white wire on top, green wire on bottom ,empty in the middle.
Nothing changed, still not working.
Any idea on what to do next, could the diod need to be replaced? It is A new part
Can you enter sw. test to confirm that this is the only problematic sw.?
If yes-->
Now that you have the sw. wired correctly,
Next step would be to look at that "z" plug at the end of that assembly and test for continuity with a meter.
Shorting the two switch wires together in switch test should get you a response. If not... you will need to look for the next "hops" for those two wires under the play field. One of the wires may have shaken loose from it's previous switch hop. May have to cut some zip ties.
-May have to refer to the switch matrix in the manual to determine these next "hops" of these GRN/BLK and WH/BLU wires.
Further upstream, if you momentarily short those two pins in the head at the connector (with a paperclip or something), you should get a response for the switch in question, in the switch test. If not, YOU got a board problem.
Isn't this fun!
