You can see how low that right ramp sits to playfield so its tight. Going off pictures I see Stern has a blocker on upper part of the ramp that goes to left drop to keep the ball on track. Without it the ball goes right off it alot. I need to find that sweet spot. The one I tried kicked it to left. Kicking around ideas for it now. Will keep posting the good and bad until its done right. Using 1/16 stainless steel rods. Tricky to weld, but they look great when done and they wont rust and easy to clean and polish.
And I put on side armor for pinfest. Did not put screws in by buttons only the rails are tight to cab. I will be taking them off after the show. But, they actually look good. The machine is really beautifull in person. More then I expected.
