Quoted from DEN:Found it.
Link: https://m.twitch.tv/dead_flip?desktop-redirect=true
Is it in 30mins from now?
1.5 hours from now
1.5 hours from now
Damn thats 01 in the night. Will be Zzzzzz then. Do deadflip have an archive? Or is it live video and gone?
Quoted from DEN:Damn thats 01 in the night. Will be Zzzzzz then. Do deadflip have an archive? Or is it live video and gone?
It will be archived on twitch for ? two weeks? Then he usually also uploads to youtube.
Don't worry, you'll be awaken by the sounds of hundreds of pinsiders crying out in terror
Quoted from TheLaw:Don't worry, you'll be awaken by the sounds of hundreds of pinsiders crying out in terror
Agreed .... i dont think its gonna play much different than the pro. Unless u like pinballs circling around the playfield as you play and the flow of the horseshoe stopped .
Or maby people likes it
It is already on.
Still haven't seen it
Finally...
kaneda23: i'm confused
therealkaneda: This is no Magic Girl
6-Month Subscriber cheer 5000 NeilMcRae: lol
kaneda23: Magic Girl sucks dick
6-Month Subscriber cheer 1000 Pinball_LIVE: @kaneda23 @therealkaneda errrr.. well this is confusing!
kaneda23: I am Chris
therealkaneda: Yeah i might sell mine
game looks good, but one of the key selling points of the LE (exploding death star) seems next to impossible to use. The pros streaming can't do it, so I have zero chance lol... I also wish the stream had an exterior shot of the game and a clear shot of the play field plastics set. Can't tell the difference vs the pro play field.
Premium/LE hyperloop is incredibly bad ass looking. But hats off to Stern for keeping the core gameplay and lighting effects equal between all versions... much like my Metallica, it makes me feel great about my decision to go with the pro!
Quoted from GorillaBiscuits:Premium/LE hyperloop is incredibly bad ass looking. But hats off to Stern for keeping the core gameplay and lighting effects equal between all versions... much like my Metallica, it makes me feel great about my decision to go with the pro!
I agree the pro is the way to go if you want sw. The huge price increase for the premiums and especially the le really dont seem justified from what i can see.
Quoted from waspinat0r:Can you not do dual missions anymore?
You can they've added added the ability to turn it off in this code
The auto-plunge sucks in this game. So many drain without ever getting a chance to put a flipper on it.
Y does the hyperspace loop fail a good bit and the balls just fall of of it and drain between the flippers? Im assuming its not supposed to do this?
Quoted from TheLaw:Painful to watch
I can't believe that game sells for $8500 shipped. I like it, I'll own it in some form eventually (used), but I can't see how someone of sound mind would spend $8500 on *that* . I was very close to not being of sound mind admittedly ... But I cannot justify rewarding Stern for this obvious cash grab.
Quoted from bigd1979:Y does the hyperspace loop fail a good bit and the balls just fall of of it and drain between the flippers? Im assuming its not supposed to do this?
Good old fashioned gravity!
Well I'm sure balls will get hung up and the middle is a planned exit area...like the middle fo the ramp in Wh20.
Did they ever crack the egg i had to leave work?
KME destroying the Death Star:
https://clips.twitch.tv/TrustworthyPlumpPoultryNerfBlueBlaster
Quoted from Darscot:The just did and it was not good.
Yeah, only half the egg cracked and the light didn't go off.
I did not see the Death Star crack open in that Elwin segment. Is it not working?
Also, when that feature actually works is it only going to be for really good players to see/achieve? That would be a waste of a toy if that is the case.
EDIT: I just watched the short clip a couple posts above and see that the egg...I mean Death Star cracked open. It seems like that should stay cracked open until the fanfare is over for that accomplishment.
Quoted from GorillaBiscuits:Good old fashioned gravity!
Right but i dont believe its supposed to do it?
Quoted from DCFAN:I did not see the Death Star crack open in that Elwin segment. Is it not working?
About 20 seconds in.
It was too hard to get to and disappointing due to some broken (or not programmed) lights. I guess both those things can be fixed with a code update.
Quoted from TheLaw:Well I'm sure balls will get hung up and the middle is a planned exit area...like the middle fo the ramp in Wh20.
I guees when the ball collide it will happen.
Quoted from bigd1979:Right but i dont believe its supposed to do it?
I got the feeling that was now the balls exited the loop. The accelerator magnets stop on the final loop which means it doesn't have enough power to keep going, so it rocks back and forth until it falls off.
Quoted from oohlou:About 20 seconds in.
Yeah. I was watching the live feed and it was not very noticeable. They need to keep the egg cracked open throughout the fanfare.
Quoted from cooked71:I got the feeling that was now the balls exited the loop. The accelerator magnets stop on the final loop which means it doesn't have enough power to keep going, so it rocks back and forth until it falls off.
I think there's a ramp on the upper right part of the loop that sends the ball down to the right wireform. I thought I saw that a few times.
Not sure what the slowdown/drop to the flippers thing was about, though.
Quoted from beelzeboob:I think there's a ramp on the upper right part of the loop that sends the ball down to the right wireform.
Yeah that's how they usually existed.
O i thought they exit on the right wireform and feed the flipper?
I'm sorry but that was not impressive at all. The hyperloop seemed to malfunction several times, I hope the Death Star was a major malfunction because it was just sad. I so wanted to be in on Star Wars and was unimpressed by the Pro and the Premium just seems to be a lot more cash for very little. This pin would be decent themed Fast and the Furious or High Speed 3 but as Star Wars it is just not good.
Quoted from beelzeboob:I think there's a ramp on the upper right part of the loop that sends the ball down to the right wireform. I thought I saw that a few times.
Quoted from bigd1979:O i thought they exit on the right wireform and feed the flipper?
You're probably right - didn't see that, but was hard to keep track of the ball on the stream.
This page was printed from https://pinside.com/pinball/forum/topic/star-wars-live-on-dead-flip-tonight/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
