I've got a line on a SW (DE). On the plus side, it has LEDs installed and playfield is in good shape. On the minus, it has (1) a potentially serious wiring issue -- sounds like the GI wiring has been hacked into some other wiring to get it to work and if you wire it properly only 1/2 the GIs work; (2) some broken plastics (Jabba's Bounty, Mil Falcon, Boba Fett and IG-88) that will be hard to find (IG-88 $12, Falcon $22, Jabba as part of set of plastics $50 and can't get Boba); (3) an R2 unit that works, but apparently was filled with some hot glue to get it to attach it at one point (not sure about this as I haven't seen it) and while it still works, likely has some cosmetic issues as well and seems to be very hard to replace; (4) playfield mylar that is bubbling up in at least one place; and (5) a cabinent that has some mismatched touch-up paint. I've talked the guy down to $1600, which still seems high to me for the work that is going to have to go into it. Any thoughts on what is reasonable and whether I'd be a fool to take on these issues for anything more than $1500?
