(Topic ID: 144565)
Star Wars data east led upgrade
By KornFreak28
  • 32 posts
  • 8 Pinsiders participating
  • Latest reply 3 years ago by KornFreak28
There have been 10 images uploaded to this topic. (View topic image gallery).
#1 4 years ago
Hello fellow pinsiders!
I just joined pinsiders and hope to talk and share info with all of you. I have Cueball Wizard and I also have a 1992 Star Wars DE. I would like to upgrade to LEDs. My question is: Is it true that for #89 and #906 LED flashers that the ground wire must be removed for each flasher in order for them to work properly? Does that apply to my machine? Thanks in advance!
#2 4 years ago
I know Cointaker sell complete LED kits, and DESW is one of them.
I am sure they would know.
http://shop.cointaker.com/category.sc?categoryId=55
#3 4 years ago
Quoted from KornFreak28:
I have never had to remove a ground wire on any of my 89/906 LED conversions from 1991-current Midway ,Stern or DataEast . I have ordered from many places. So not that I am aware of. I LED my DataEast STAR WARS the LED flasher all worked fine.
Quoted from Jasontaps:
Melissa is great . I talked to her today in fact. But I would not buy a LED kit for STAR WARS . I did and it was incomplete . Some good ideas but not as good as I could do . It is the one and only LED kit I ever bought. I sent it back. You will have better luck using you own creative mind . PM me if you need some suggestions . Peace .
#4 3 years ago
Thanks for the respose guys! The reason why i asked the question about removing the ground wires is because the LED kit for Star Wars on marcospecialties has a little side note on the description that tells you to remove the ground wire for each 89 and 906 flasher. I spoke to Chris from CT yesterday and he said that it does not apply to my machine. I just wanted to confirm with you guys who actually own the same machine. Its nice to know that I don't have to worry about that. So you guys dont think the LED kit from CT is worth it? I would like to sort of assemble my own kit, but how would i be able to tell how many 555 and how many 44 i need? I looked at the Machine's manual and is all wrong. In some lamps, the manual tells you its its an 89 (c3-po)and in fact its a 555. Is there a list out there of the correct lamps? Or will i have to lift up the playfield and visually check each lamp? Your help is very much appreciated.
#5 3 years ago
Wow your machine looks awesome! Very nice!
#6 3 years ago
I know there is another thread going here right now about led's vs blubs. I am a led guy. I love the color and brightness of them.
#7 3 years ago
I bought and installed the coin taker kit from Coin Taker. I loved it. I then played it a while before making a few personal preference changes. It is a great way to start and get you very close to where you want it to be. For a very few dollars you can make some of your own changes. The LEDs look very impressive on this machine.
#8 3 years ago
Welcome to Pinside. If your interested come join the DE Star Wars club. To find it go to "All Clubs" and look for it. There are great pictures and help threads there.
#9 3 years ago
Will do! Thanks!
#10 3 years ago
Hey txstargazer3,
When you bought your kit from CT, did they include blue leds for r2d2? What about the exposed lights at obi-wan (red) the 3 yellows (han solo) and the red, green and yellow at emperor palpatine? Color matched? Are those super brites or frosted? Are they the same type (frosted or supers) as the rest of the insert lights under the Playfield?
What type and color did you get with the kit for the GI? Backbox? And flashers? All white? Frosted or retros or superbrites? Do you get a map for guidance on installation? Thanks!
#11 3 years ago
That was a couple of years ago and I have since sold the machine, so I don't remember that level of specifics. Sorry! They did come with a map for installation.
#12 3 years ago
I responded to your PM you sent me.
#13 3 years ago
Quoted from txstargazer3:
Thanks so much!
#14 3 years ago
Quoted from RobKnapp:
I just responded, thanks so much!
#15 3 years ago
SW Data East looks great with LEDS, here a few pics of the one I recently sold
#16 3 years ago
Quoted from Esoteric_rt:
Wow! Looks awesome! Question: What kind and color GI bulbs did you put in the machine? Retros or frosted? Blue? What about the color of your flashers? Did you install frosted leds on the exposed lights at obi-wan, han solo and emperor palpatine? Thanks
#18 3 years ago
categoryId=55
#19 3 years ago
They were all from pinball life, non-ghosting frosted bulbs in the GI (mostly purple and cool white, maybe a couple of blues), all flashers were LEDs also, just a mixture of colors from memory
The best way is to buy a few extra and see what looks best in each socket, that's part of the fun
#20 3 years ago
Thats a great idea! Will try that for sure, thanks!
#21 3 years ago
Some pics to see other looks.....
#22 3 years ago
Quoted from OLDPINGUY:
Wow! Can you tell me which color whites on the top and which color whites on the bottom picture? Thanks
#23 3 years ago
Love the brighter whites on the bottom pic....do you know what kind is that? Frosted? Or super brites? Thanks
#24 3 years ago
Yes, They are all frosted, to avoid spotting.
The whites are all 5050 1 SMD, thats the single square diode, "retro" at CT.
Theres a Single 2 SMD in the center to pull a bit brighter for depth of field.
The green Yoda is a 6mm frosted.
Colors used on People were frosted Sunlight.
Kits will give you the same bulb in all spots, which is fine, other then Yoda. The brighter bulb causes the green to flow
into the letters, so a dimmer LED is used.
It is my opinion to stay all frosted, and simply chose your brightness level.
The game looks stunning in White or Sunlight, and a bit of color added to the playfield...be it some Purple, Blue, Red, or Ice Blue.
But mostly, 90% of your backbox, and general illumination, is white.
You can color match all your inserts, same frosted, in Twin 2835..red with red, green with green, etc.
But if you use 1 level lower in brightness, a 1 SMD, you would use Warm White in your Yellows and Oranges,
It isnt hard...the hardest is trying to get it perfect to Your taste, with only one attempt,
Dont be afraid to experiment..color changing bulbs, new colors, strips. to try out,
You can go conservative, or light to play in the dark.
This link might help with many of your questions.
http://www.cometpinball.com/category-s/1825.htm
Many great vendors for you, and sales coming up this week.
Art
#26 3 years ago
Art
Nice! I really really appreciate all your help with this project! Very good info! Thanks!!!
#27 3 years ago
Wow! Thanks for the info! Really appreciate it!!
#28 3 years ago
Art
I have another question if you don't mind: Is it true that for flashers # 89 and # 906 that the ground wire must be removed for each lamp? Or else they wont work correctly and just stay ON? I read that at marcospecialies on the description for their Star Wars Led kit. Did you have this issue with yours?
Also, did you add color to your flashers? Or just kept them white? Thanks!
#29 3 years ago
I don't recall any issues, and tend to color match flashers....control the brightness of the ones close to your eyes in any
Game, to not blind players.
Art
#30 3 years ago
Art
Awesome! Thanks!
#31 3 years ago
I recommend adding an Energi Maestro to smooth out the LEDs. I love LEDs but they can be harsh! It is a well designed product. Very easy to install and setup, no software required. I put one in DESW and BF and it makes the game more enjoyable.
https://pinside.com/pinball/forum/topic/led-gi-smoother-for-data-east/page/5#post-2636911
#32 3 years ago
Quoted from Jgaltr56:
Cool! Thanks!
$ 9.99
$ 14.50
PinballElectronics.com
5,495
West Chicago, IL
5,495
West Chicago, IL
Ballston Spa, NY
