Friend was playing my game. All of a sudden color DMD drops off and game starts randomly shooting balls from the launcher. Balls are then stuck in the subway and it will not put them back in the trough. 2 coils are randomly firing and I cannot use flippers or anything but can start a game.
I have a shady high power board so i'm sure that's the culprit, its had some "work" done to it prior to my ownership. Test point 1 reads 0... since it is unregulated 12V it should read .... 12V right? Yes I just want to be sure if this is the main culprit.
18V is jumping up and down from 15v-19v (assuming that's normal since it's unregulated).
I have put in the old screen, that screen will turn on, game remains the same.
I've troubleshooted with the WPC guide before but one thing is confusing to me when testing BR's and Caps
It tells me to turn on the game testing BR2, okay easy enough. However then it just says this below... Am supposed to stay connected to a bridge rectifier to test a cap? Am I confused?
For the capacitor, turn your meter to AC volts. Note that inexpensive meters may give false readings here. Ideally, your meter should be a true RMS meter. Good capacitors will read about 300mV AC. Bad capacitors will read up to 2VAC. Anything over 1VAC indicates a failed/failing filter capacitor at C5 which should be replaced.
Anyways just not sure what I should be looking at next, just looking for some advice prior to digging into anything.
