I just picked up a st:tng in immaculate condition. A 9.5/10 for sure...clean and solid. I played it multiple times before i bought it.
I get it home, small, smooth trip, game secured and protected.
I set it up, turn it on and game goes bonkers...not start up noises..im talking going bezerk!....launching probes with no balls...ball checking over and over.....just everything going off like crazy. Well one ball was resting between the glass and trough cover. Apparently dislodged during trip, so i dropped it back in thinking thats why the game was going nuts.
I start another game..still going a little nutty but not as bad as initial start up but still acting weird during game play...like throwing out a ball into the proble launcher while im in the middle of playing a game.
I only count 5 balls....pin does ball check, still, only 5 balls. I lifted play field..no 6th ball anywhere. The manual says the game uses 6 balls..and the multiball is 6 balls. So i take a ball from another pin and drop it in the trough to make 6 (2 locked and 4 in the trough). I start another game and it shoots two balls into the trough. It does this twice...now im cofused...i have 6 known balls in the game now and its doing this.
So i take the 6th ball back out, start a game and it plays fine...i played 3 games and no issues (still with only 5 known balls and no ball checking going on before during or after gameplay). I get to a Borg multiball and only get 3 balls which i should get 6 correct?
So being i played 3 games with no issues with 5 balls, is there a location on the game where a 6th ball is locked and i just ain't seeing it or its jammed or something?
I pretty distraught over this after the kind of money i dropped on this pin and from the first second i have it home i have issues with it.
Why if i put a 6th ball in there from another game it spits out two into the trough...should the trough only have 3 balls in it at all time and the other 3 stay locked somewhere??? i know two do but that 3rd one, where the heck is it????
Currently the game has been on, not played for last 20 minutes...3 balls in trough...no ball checking going on..no diagnostics going on. The game seems to be right with 5 balls..UNLESS of course there is that 6th one thats locked somewhere and is registering as the 6th ball wherever it is at.
Page 1-35 of manual says if a ball is missing it would show up as an error code.
In test T-18 (pages 1-8 and 1-18) i press enter and no ball clearing takes place. The display shows "Removing all balls from under playfield" and the game does nothing and there are only 3 balls in the trough. The directions clearly state during T-18 all balls in poppers and troughs will be kicked out.....no balls are kicking out....the game is 100% idle with zero sound..no ball kicking or checking...nothing..nada..zilthch.
Where is that freaking 6th ball dang it!
I hope im clear with my description...and any guidance will be helpful.
