(Topic ID: 339934)
Star Trek TNG Flippers Stuck
By Romulus
7 months ago
  • 16 posts
  • 6 Pinsiders participating
  • Latest reply 7 months ago by Pin_Guy
#1 7 months ago
I have a STTNG machine that the flippers were working fine on, I added the Hallmark Warbird (which only connects to one GI and one flasher bulb, and I replaced a defective trough opto board and now as soon as my game starts up, both of the right flippers hold in the extended position. I turn the machine off and they drop back to retracted. Any advice guys?
#2 7 months ago
Update, I have both unplugged the Warbird, and put the old opto board back in and the same thing keeps happening.
#3 7 months ago
Anytime alligator clips and high voltage are involved something might get shorted.
Did you install the mod AND the new trough board at same time, and then turn the game on and find flippers not Working?
Have you checked fuses? It’s possible you shorted out the opto power.
If you disconnect the flippers from the flipper opto boards, do they drop?
#4 7 months ago
Quoted from Romulus:
Take clear pictures with flash of the opto boards you have re-installed including the connectors and report back.
#5 7 months ago
I did install both at the same time. I don’t think I shorted out the opto power because I can do a switch check on it and all of them are working. I know it’s an electrical problem since they return to normal when power is removed. The only other thing that might help is when I do a flipper coil test, neither of the right flippers hold. They flip and return fine for the power test, but in the hold test they don’t move.
#6 7 months ago
Here are the requested pics, if I missed one left me know. On the opto boards, the old ones are on top.
IMG_4650 (resized).jpegIMG_4650 (resized).jpegIMG_4651 (resized).jpegIMG_4651 (resized).jpegIMG_4652 (resized).jpegIMG_4652 (resized).jpegIMG_4653 (resized).jpegIMG_4653 (resized).jpegIMG_4654 (resized).jpegIMG_4654 (resized).jpegIMG_4655 (resized).jpegIMG_4655 (resized).jpeg
#7 7 months ago
It sounds like an opto issue. Check the fuses like I said.
If your optos are dead, it can cause this switch issue. And it’s a switch issue (they don’t go up till you hit start.)
Once more: check the fuses. Always check the fuses first.
#8 7 months ago
Ok, originally I only replaced the Xmitter opto board cause that was all that was broken. After taking the photos, I decided to go ahead and change the receiver board. After doing that, the upper right flipper works now but the bottom one is still doing the same thing. When I disconnect the cable from the right flipper button, the stuck flipper drops.
#9 7 months ago
Every fuse I can find are good.
#10 7 months ago
Are you looking at the big driver board on bottom right, as well as the smaller board top left (fliptronics)? Those control flipper high and low power, hold etc and are fused as well. Make sure you physically remove the fuse and test for continuity using a DMM... Fuses can deceive you by only looking at them.. Ive seen some that looked brown and completely blown actually not be... and ones that look perfect test bad.
#11 7 months ago
Try disconnecting your flipper button light and see if that helps.
#12 7 months ago
LTG got it. Even though I’ve had that light for months and never had a problem, suddenly it started causing a problem. Thanks for the help folks.
#13 7 months ago
mo' alligator clips, mo' problems
#14 7 months ago
Oh it wasn’t an electrical problem. When the playfield came down, it physically pushed the led bulb down and it interfered with the flipper opto board
#15 7 months ago
Glad you found it!
Mods can cause lots of problems that people never had seen when the game was on the route.
This was good troubleshooting!
#16 7 months ago
horrible mod. this is what a a flipper button light mod should look like. (flipper control removed for clarity)
$ 250.00
Professor Pinball
Interactive
$ 219.00
Lit Frames
Decorations
$ 37.50
Other
$ 64.99
$ 26.50
Gweem's Mods
Sound/Speakers
7,250
Orange, CA
Pin Stadium Pinball Mods
Led
$ 1,059.00
$ 259.99
Toppers
6,000
Warner Robins, GA
$ 39.00
Arcade Upkeep
Other
Other
Flashinstinct
Decals
PinSound
Sound/Speakers
$ 109.95
PinSound
$ 40.00
Protection
7,000
Shrewsbury, NJ
$ 399.00
Decals
$ 64.00
Lighting - Under Cabinet
Under cabinet
$ 95.00
Pinball Mod Co.
Sound/Speakers
$ 16.50
Led
$ 27.99
Lee's Parts
Interactive
$ 25.99
Lee's Parts
Led
6,500 (Firm)
Eastvale, CA
$ 199.95
PinSound
This page was printed from https://pinside.com/pinball/forum/topic/star-trek-tng-flippers-stuck and we tried optimising it for printing. Some page elements may have been deliberately hidden.
