(Topic ID: 95058)
Star Trek playfield Laser
By oscarspa
5 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by Excalabur
#1 5 years ago
Hello, I observed that the multiball mode playfiled the laser is not active, I do not find in the maintenance menu where I can test,can you tell me where I can see if it works or not?, And how to get fix, greetings.
#2 5 years ago
If you have the Pro model it doesn't have the "laser".
#3 5 years ago
I have the le model, regards.
#4 5 years ago
Under the apron is the laser , there is a band around the button that activates it , make sure it hasn't slipped off , I read somewhere that this happened to one person .
#5 5 years ago
Thanks,I removed the apron and get two wires to the motor and two wires to the laser, I have not seen any band, I found the test number 20 of the coils and it works, but is not active in any of the multiball of missions, I have version 1.42, if I worked before, I've also looked in settings and the laser is active, any suggestions.
#6 5 years ago
Another cuestion, is it possible to change the red laser for rgb laser?, regards.
#7 5 years ago
There's no such thing as an RGB laser. You could swap it out for a green one if you want it to be brighter, but don't put anything above class 2 in there if you value your eyesight--the pinball presents an eye hazard otherwise.
#8 5 years ago
I saw blue-purple ones on the net so that could be an option too...
#9 5 years ago
You can't get a 405nm (violet) or blue laser bright enough to look good without being dangerous. Your eye's response at that wavelength isn't good enough to make the starfield effect at a safe level of light.
There was a brief fad for blue laser pointers amongst laser physicists until everyone realised that they were really terrible: you could either worry about putting someone's eyes out/violating the law or have a totally lame pointer.
Great American Pinball
