Working on a Star Trek next generation & the right side cannon will not fire the ball. The left cannon will rotate at start up & fires the coil. I checked optos there & they appear to work correctly. If you interrupt the opto signal on either cannon they rotate but Only the left side fires the coil. I have checked continuity of the wires in that side loom and I have continuity on all of them including the two purple wires for that coil. I have also run the cannon test and mark switch and home switch are both closed when the cam is in top position. they are not synched up exactly but appear close enough from what I can tell. I have read several other similar repair threads that mention replacing the wires in the looms as a fix but with them passing a continuity test its puzzling.
