Quoted from BizPop:Hello, been playing my STNG game for a long while now. I've noticed that my balls never get into the Borg, and so they never spit out of the Borg either. The channel switch behind it seems to be working.... but it ALWAYS channels the ball to the ramp that brings it near the front of the play area. Is there a setting I need to change to get this to work? Thanks!
While I'm at it, I've noticed that my original DMD is starting to develop a lot of visual static. Any recommendation there? Thanks.
Your diverter at the top of the ramp is probably stuck and doesn't move when the coil fires. I've seen this on both STTNGs I owned, as well as others. Need to take that whole thing apart if you can't easily move it with a finger from the backboard to the fully engaged position and clean out all the old grease (that's now basically glue) that someone over-lubricated with at the factory or at home.
*Edit* Also, if I'm remembering right, you HAVE to lock the first lock ball in the ship, not on the right orbit, or you lose the chance to lock balls in the ship. That's a code thing, nothing to fix there, but might want to test that out by hand if your diverter moves and see if it answers your question.
