Some people will care that it is a reimport, some won't. Condition is what matters. STTNG is a very expensive game to fix up. Expect to pay high 3's to low 4's for an average machine. A nice one should pull more due to the cost of parts and the crazy amount of labor to fix it.
Things to look at on a STTNG.
Ramps tend to crack, they are 300 to replace all 3.
Playfield tends to get wear. The teal shield inserts in the middle of the playfield can melt or ghost badly. Micro has made playfields I believe they are 850.
Borg ship at the back of the playfield tends to warp from heat. It is available, pinball life has it for 60.
Cannon covers tend to break. 35 a piece from marco
Cannons tend to not work (wiring harness breaks inside). 50 for the pair from marco/
The delta quadrant ramp has a diverter to send the ball into the borg ship. This tends to get gummed up and not work. (time consuming, but free fix)
Trough optos tend to fail due to vibration. There is an upgrade to replace/fix this, but it is oos from what I have seen.
Trough can wear out. 125 to replace from marco for the upgraded trough. Someone makes an insert that is cheaper to fix it.
Subway optos tend to fail. Cheap fix, but annoying to pull the trough and replace optos.
Cabinets get slight fade, but the bigger issue is the head decals have a blue base. When they get scratched you get blue. Head decals are available separately from full cab sets. Cab set is 300.
