(Topic ID: 90602)
Star Trek LE: Drop target won't stay up
By filthyPierre
6 years ago
  • 61 posts
  • 24 Pinsiders participating
  • Latest reply 4 years ago by RoyF
  • Topic is favorited by 27 Pinsiders
There are 61 posts in this topic. You are on page 1 of 2.
#1 6 years ago
Hi,
Last couple of times I've played my STLE, when I hit start to start a new game, the drop target goes up and down 3 times, while the Vengeance drops forward like it's been hit, three times. After that, the ball feeds to the plunger, and the Vengeance resets to normal up position. The drop target stays down, and stays down for most of the time. The first time you get a ball in under the Vengeance, it immediately starts Vengeance multiball. Occasionally, and I say very occasionally, a ball will go in and the target will come up and stay. Unfortunately, sometimes this happens in the middle of Vengeance mode and the shooter at the back of the Vengeance will fire the ball back, only to hit the drop target and fire straight up and hit the Vengeance, or fire over the front of the drop target to land somewhere down on the playfield or crash into something. Once it jumped over into the pops. Not good.
In diags, whenever you hit the select button to bring the target up, it comes up but immediately goes straight back down. If I recall correctly, it's supposed to stay up until you give it a "Down" command.
Any ideas what to check? Seems like a sensor or switch I guess. Anybody else seen this?
Cheers,
FP
#2 6 years ago
Sounds like you have a bad opto... Mine had the same issue, the opto on the right under the vengeance was bad on mine. The good news is that Patrick at stern will send you new opto's no problem! the bad news is that the right opto is a PITA to get to. I would double check the connections under the playfield where the optos plug in (reseat them) maybe you will get lucky.
#3 6 years ago
Ha, that'd be right. Thanks for the tip, I will check it out. Probably have to go through Aussie distributor to get the part though. Cheers, FP.
#4 6 years ago
Mine also did that but I just adjusted the spring so it's tighter and holds the target in place
#5 6 years ago
Quoted from Gorgar1:
Forgot to mention I also tried this (see pic) before replacing the opto but it didn't help my machine.
The little board the opto attaches to on my machine had a bad connection causing it to randomly trigger. If I put the game in switch test mode the opto would randomly trigger even when I wasn't touching the machine.. I believe it was switch #33
#6 6 years ago
I had this problem, or a similar one, and it wasn't an opto or switch or anything, was purely mechanical. The screw on the drop target that's on the same side as the spring was pushing it so it wouldn't latch properly. Weird behavior like phantom hits, popping up and down rapidly etc. Sound familiar?
My solution was to take out the screw on the spring side, and feed it back in from the other side, so the head wasn't interfering anymore. It won't "bite" anymore, threads won't catch on the plastic, but the other screw holds it in place, so it work fine.
Ever since I made this fix (Rarehero gets the tip for this being the problem, I think he found a smaller screw head though) I haven't had a single repeat of the issue.
#7 6 years ago
Quoted from Aurich:
Yup, this is most likely the issue, not the opto. The target is getting pushed by the screw head. I found a screw with a slightly smaller head and haven't had the problem since replacing the stock screw with it.
#8 6 years ago
Thanks for all the tips fellas, I will check those out as well. Cheers, FP.
#9 6 years ago
it must be the Enterpirse effect - my STTNG top target does the "up/down" thing all the time. Have to see if it's similar. Picking up my STLE NIB tonight. Small diversion in blood flow>.....
#10 6 years ago
Well I finally got a chance to work on her this weekend just gone. Funnily enough (or typically), when I played a game before I ejected the balls, the drop target behaved properly for the first few minutes, then did the down/up/down/up thing a few times.
Anyway, I pulled the drop target assembly out and it appears to have been the latch problem as described in tech bulletin 165 above. I saw the screw that holds the black plastic latch to the metal bracket. At first it looked like it was maybe touching the drop target and causing it to not latch properly but examination under a magnifying glass showed that it wasn't interfering with the target at all... close but not quite. In the end I did what the tech bulletin said - I pulled the latch off and put two small washers underneath to raise the latch by about 1/16". Interestingly, there was a grey card shim underneath when I removed it. This is obviously an attempt to fix the issue, but not quite on the mark. Once I'd put it back together, it all plays as it should, with no spurrious down/up/down/up/downs.
Thanks for all the suggestions, looks like it's behaving itself now, but time will tell.
Cheers,
FP
3 weeks later
#11 6 years ago
Quoted from filthyPierre:
Cheers,
FP
Thanks. I had the exact same issue. The latch was only holding the drop by about a fingernail. Added washers and back to normal.
3 months later
#12 5 years ago
Quoted from TomGWI:
Hey there, can I ask you guys whether you had to remove the whole drop target assembly to insert the washers under the screws, or were you able to do the fix with the assembly in place? It sort of looks like if I can get the right angle with a screw driver, I might be able to loosen the screw and slip a washer behind it. But, I figured I would ask how others did it before giving it a try myself. Thanks!
#13 5 years ago
Quoted from Nokoro:
Remove the assembly. It is only a few screws and will be much much easier to access. Tales less than ten minutes.
#14 5 years ago
Quoted from TomGWI:
Thanks. For some reason, it looked more complicated than that. Good to know that it is fairly simple.
#15 5 years ago
Quoted from Nokoro:
My advice is remove one screw from the black spacer lip and loosen the other one. Put the washer in behind the black spacer and place the screw and then remove the other one. Hope that makes sense.
#16 5 years ago
Quoted from TomGWI:
It does. Thanks!
Do you remember if you had to disconnect the electronics when you removed the assembly? If so, were they just plugs?
#17 5 years ago
Quoted from Nokoro:
It does. Thanks!
Yes there are plugs, no soldering needed.
#18 5 years ago
Thanks. All of my prior experience was with an old Bally. Nothing was easy with that.
#19 5 years ago
Easy fix with the washers.
1 month later
#20 5 years ago
Anyone able to take a picture on how the washer are suppose to be installed. I am not quite getting it as my drop target still is going up and down on its own.
#21 5 years ago
Take out the two screws that hold the plastic shelf to the bracket and put the washers between the shelf and the bracket. Reinstall screws.
#22 5 years ago
Quoted from Imeh:
image.jpg 337 KB
#23 5 years ago
It works well. Another common issue is that the spring tends to pull the target to the right and it may hit the head of the right shelf bolt and that keeps it from seating well. A flathead screw will fix it if yours still has issues.
#24 5 years ago
What size washers?
#25 5 years ago
Look at the pic. They need to be small washers. Backing washers for rivets will work if you have any.
#26 5 years ago
Quoted from rai:
What size washers?
The Stern bulletin says 1/16". I still have to try this myself. My drop target is getting worse by the day. My after Thanksgiving project . . . .
#27 5 years ago
#4 thin washers work great
#28 5 years ago
Glad this got revived, just started having this same problem. Stupid pinball fixin when I want to play!
#29 5 years ago
Just fixed the issue with mine by putting the washers in place. Worked like a charm. I'm always amazed when I successfully fix something on my pins (especially without breaking something else).
#30 5 years ago
Sorry no pics atm but here's the easy SKB lazy way of fixing this (since it's a PIA to get to those screws):
With the playfield upright, it's the screw on the left that needs a washer. Right one doesn't need it. Get some diag cutters and cut a small space in the washer (about 1/4 of the washer). Loosen the screw but do not remove it. Squeeze the washer in, tighten the screw. 15 mins fix. It's a little tough to get the washer in cause space is so tight. Just be patient and have a magnet handy in case you drop the washer.
SKB
#31 5 years ago
Quoted from Eskaybee:
SKB
That will work.
But I had no trouble by myself as the entire mech comes out with only 4 screws and two molex plugs.
Also a good time to clean the opto while you have it out.
#32 5 years ago
Quoted from Nokoro:
Well, I spoke too soon. I eliminated the problem with phantom, repeated hits. But, I created a problem where every once in a while, hitting the target wouldn't register a hit. May theory is that the 1/16" washers may have been a tad too thick. I found a thinner pair of washers lying around the house -- call them 1/32" but I don't really know. Anyway, for now, that seems to have worked. (Of course, I thought I had this fixed yesterday, so I need a bunch more games on the machine to tell for sure.)
#33 5 years ago
When you remount the assembly to the Playfield take care to position it so the target is clear of the playfield. It must be able to get knocked off the shelf and if there isn't enough clearance you will have the issue of it failing to drop when struck on occasion.
#34 5 years ago
Quoted from Imeh:
Maybe that was the problem, but what do you mean? There seemed to be only one position to put it back in -- I just aligned the holes and put the screws back in the assembly to mount it.
#35 5 years ago
Quoted from Nokoro:
Yeah, I'm having that same problem too. Might need to try thinner washers.
#36 5 years ago
There is no real adjustment, just tweak it as you tighten it down. It must have clearance between the target and playfield. You may have to go with thinner washers if you can't get clearance.
#37 5 years ago
I found that it was an issue with the rounded head of one of the screws preventing the drop target from "latching" to the lip that it rests on. (The drop target can move VERY SLIGHTLY off-center from time to time.) I replaced the round head screw with a countersunk one and haven't had any issues since. No washers needed, but each case may be different.
Hope it helps!
Post edited by MrDo: Clarification
#38 5 years ago
Quoted from Aurich:
I'm still getting the occasional hit that is failing to register, though it seems less frequent with the thinner washers. Maybe I need to try just one thin washer on one side. There's probably a sweet spot that is a bit machine dependent. Kind of frustrating.
Quoted from Imeh:
I feel stupid, but I'm just not getting this. My target seems centered in the slot. If it wasn't clearing the playfield, I don't think it would work 98% of the time like it is doing.
#39 5 years ago
I had done the washer method quite a while ago - traded ST to a local guy - he gives me a call a week later stating the drop is having the same behavior. Take out the drop unit and the plastic ledge was shattered. I'm going to try a thicker shim that goes across the entire ledge so it doesn't have a chance to break again.
#40 5 years ago
I added washers, prevents multiple drops on one hit, but now a really firm hit does not cause the target to drop at all. Makes for STM drain.
Do you think this is because the washers are too thick? Or is there anything I can try to fix this behavior?
#41 5 years ago
It's most likely a clearance issue with the target and the playfield. There has to be enough room for the ball to knock the target back off the shelf. If the washers are too thick, it can cause this, but you may be able to tweak the position of the assembly a little as you tighten it down to get clearance also.
#42 5 years ago
It can take two people to diagnose this, one to shoot, and the other standing at the side of the game watching the drop. That's how we figured mine. The drop was too far back, probably because of the washers, and practically pressed up against the wood of the hole. Ball would whack it hard, but it just couldn't get pushed back far enough to reliably drop.
You can't see this from the front of the machine, why having a second pair of eyes helps.
We took the assembly off and bent it slightly, and installed it keeping it as forward as possible while tightening the screws.
Problem solved, had a league event with 35 people playing it all day, no problems.
3 weeks later
#43 5 years ago
My drop target started acting up again yesterday. Turns out the black plastic shelf broke in half. $3 to order a new one so not bad but I believe the problem was I used too thick of washers on mine. Just thought I would let others know who have done the adjustment.
#44 5 years ago
Quoted from TomGWI:
The guy that bought mine has broke the plastic shelf twice now. He had a metal one fabricated - don't know how it is working yet. 2nd time I put a thick fish paper behind it and it still broke.
#45 5 years ago
Quoted from WeirPinball:
Thanks. I was thinking about making a metal one as well.
1 month later
#46 5 years ago
Quoted from TomGWI:
This just happened to mine. Where did you order the black plastic shelf? Directly from Stern?
Thanks.
#47 5 years ago
Quoted from Aurich:
Aurich, I'm still having this problem of an occasional hard hit not registering. Can you tell me how you bent it? Just with your hands? Also, in what direction? I think to get the target to lean forward more, you need to bend the assembly from a right angle to a slightly obtuse one, correct? Thanks!
#48 5 years ago
Quoted from dphelps:
Thanks.
My shelf just broke as well -- it is cracked but still functions for the moment. I emailed Stern. Amazing that in this day and age, a simple drop target is giving people so much trouble.
#49 5 years ago
Thanks.
Pinball Life has them
#50 5 years ago
Quoted from TomGWI:
$ 259.95
Pin Stadium Pinball LEDs
$ 84.95
