Anybody know were to download the latest 1.3 version of the code for premium and LE machines.
Looked on Sterns website and says not released yet?
Mines running 1.2 but sure have seen other owners with 1.3.
From UK so a bit expensive to call them. I will email - just seems funny mine is quite a late one and yet has 1.2 code.
All videos of LE's I've seen around are all 1.3 as they show the modified match. Strange to hear about a 1.2 LE. You might even have the Pro code installed. How is it playing?
Plays very fast and haven't encountered any obvious problems apart from a bulb out and poorly applied stickers - warp ramp is actually missing a chunk out so that will be a headache to replace.
It is odd it is running 1.2 as it's a high number. Most strange.
Quoted from sillyoldelf:From UK so a bit expensive to call them. I will email - just seems funny mine is quite a late one and yet has 1.2 code.
Yours had to take a boat trip, so it prob had the code they had at the time
JJ
Cheers. Seeing some major dimpling already. Balls go round with some force. Everybody else getting this?
Quoted from sillyoldelf:Cheers. Seeing some major dimpling already. Balls go round with some force. Everybody else getting this?
I'm getting pretty heaving dimpling, but I've had that on XMLE and Tron as well. Seems to be a function of the speed of the game. I wouldn't worry about it too much, just keep playing to even it all out.
-Wes
This will happen and will be worse than other games. Stern seems to have put some extra clear coat on this title which makes the PF looks scratched and dimpled quickly.
I'm not complaining about that! I welcome more clear coat and am happy with STLE though you will see a lot more dimpling with thicker Clear Coat.
Good to know. Was going to turn the coil power down. Just waiting for it to update to 1.3
Some tricky shots on this game starting modes.
Dimpling happens on all games. I think the bright lighting mixed in with the bright pf art also makes dimpling more apparent.
Speaking of the wicked force on this game, Has anyone gone airborne on the right ramp? Usually when the ball returns from the left orbit and I one shot it to the right ramp, the ball travels so hard it goes airborne. The protector does not catch this and sometimes rejects the ball back down the ramp. I was at approx 6.8-6.9 pitch when this was occurring and did back it down to 6.7 and noticed a big improvement, but still got one or two after about 20 attempts.
Yeah some airballs for sure - even one that led to a drain. It does seem to be settling down the more I play it. Might be worth trying the coils dialled down - soft setting?
Quoted from sillyoldelf:Yeah some airballs for sure - even one that led to a drain. It does seem to be settling down the more I play it. Might be worth trying the coils dialled down - soft setting?
Air balls from slingshots? Need the 4 ohm resistor fix I posted in the Metallica thread
Quoted from sillyoldelf:I turned slingshots down to 18 in settings and that fixed it.
This is new!
Quoted from markmon:Cool. Those are new adjustments.
No kidding... we wouldn't know though would we...
Anybody have any alignment issues with the DMD dots? Noticed this last night. Some rows are slightly out and it is noticeable on some animations.
Quoted from sillyoldelf:Anybody have any alignment issues with the DMD dots? Noticed this last night. Some rows are slightly out and it is noticeable on some animations.
Was wondering the same. It would be sad that DMD dots not perfectly align these days.
I have the same problem of dimpling! i'm afraid of that after only two days... I'll try to put the coil power down too...
For the alignment, i have the last row a bit out, but we need to see this closer, it's not really noticeable.
Anyboby can sent me the 1.3 code?? i can't wait for stern!!
Quoted from Guitoone:I have the same problem of dimpling! i'm afraid of that after only two days... I'll try to put the coil power down too...
Sent
The DMD's sterns are using are lets put this nicely not the best - so its normal. However you can get a replacement if your really unhappy or its really noticeable.
Anyone know where to download 1.3 code for STLE please>?
Stern still is not showing any codes for the LE
Quoted from Squizz:Anyone know where to download 1.3 code for STLE please>?
I send the code that Gexchange mail me yesterday. Thanks again, Gexchange.
I don't notice any change on gameplay yet, do you see one? Only DMD animations?
You can't avoid the dimpling. If you look at any well played game you'll see the playfield is just covered in dimples. That's just what happens when a steel ball hits a sheet of wood.
I got it off the distributor on a USB stick when I picked up my game
Quoted from frolic:i think we are noticing the dimpling more because the playfield is so well lit.
It's also the TYPE of game. High energy high speed games get 'em more than others. For example I have my MM next to CFTBL... MM is shiny but evenly dimpled... high speed and troll heads throwing the ball around do this.
But CFTBL - older and more played... has virtually NO dimples... slower game and the ball never leaves the PF.
Just politely rolls around
You're right also - LED's definitely make those dimples glitter.
Quoted from Gorgar1:I got it off the distributor on a USB stick when I picked up my game
Have it now
As long as the ball does not deviate too much. I played a pro during launch event that was almost bubbly near the flippers and the ball would change slightly trajectory. I hope it's a one off. Or are those called dimples?
Quoted from astaroth:As long as the ball does not deviate too much. I played a pro during launch event that was almost bubbly near the flippers and the ball would change slightly trajectory. I hope it's a one off. Or are those called dimples?
Nonsense. Playfield dimples do not move the ball off trajectory. More likely there was ball spin in play.
Quoted from sillyoldelf:Pm me if anybody needs it.
Hello,
just send you a PM request for getting LE version 1.3
Regards,
Bigmac
