It must be hard to be a designer at Stern having to make two of the same pins only different, twice the work for designer & software, This might be why code take so long
Quoted from RobT:Trust me, it isn't a "false" rumor.
I know man... I was just busting his... well you know...
Like all things I consider the source and you sir are a good source! Well... ok maybe not all the time!
Quoted from Eskaybee:I heard they will be adding a feature to make up for it. I don't know if it will be an LE only feature or not. And from what I heard, its not a design change to the layout persay, but something to function more within the rules to indicate to the player what's happening as they 'battle' their way throughout the game.
Now this sounds interesting. Possible higher level of integration of the laser usage or a complete new feature.
Very cool if this is true
Quoted from Part_3:Can't be LE only.....Premiums and LE's are joined at the hip code and playfield wise.
Ya both LEs and Premiums. Just mentioned it on the LE since they will be shipping first.
Quoted from SDTM:Ya both LEs and Premiums. Just mentioned it on the LE since they will be shipping first.
But I was quoting Eskaybee......
Quoted from Part_3:But I was quoting Eskaybee......
I said that because its not a playfield redesign.
Stop "Shielding" your information
Quoted from sk8ball:Stop "Shielding" your information
ROFL! I see what you did there
Quoted from Kiwipinhead:All that will happen is they will spin the VUK 180 degrees so the ball comes down the left ramp to the left flipper, That sucks ... but watcha gona do
If it goes to the left flipper that's stupid, there's no need for the VUK at all then, the scoop returns it there. If they did change the VUK to return to the left flipper I will cancel my LE order.
Quoted from QuarterGrabber:If it goes to the left flipper that's stupid, there's no need for the VUK at all then, the scoop returns it there. If they did change the VUK to return to the left flipper I will cancel my LE order.
You might as well as cancel then. The new VuK will be a smoother/better return than the pro. Some of the videos I've seen, the pro return kick doesn't make it into the outlane but bounced to the flipper. Not very smooth. You're also forgetting that there are plans to add a feature. Whether they do it or not is still to be determined.
Quoted from Eskaybee:You might as well as cancel then. The new VuK will be a smoother/better return than the pro. Some of the videos I've seen, the pro return kick doesn't make it into the outlane but bounced to the flipper. Not very smooth. You're also forgetting that there are plans to add a feature. Whether they do it or not is still to be determined.
I agree, having the redesigned VUK is better than not having one for sure. Can't wait to see what has been added. I should of figured SR would not just pull out an advertised feature in one of his designs without replacing it with something cool. Still very much looking forward to seeing the finished Premium model. I would go LE if I could find one for $7500 to the door but I don't think that is going to happen so looks like it will be a Premium for me if all looks good on the unveil. November can't get here fast enough for this pinball addict!
If true it's too bad they didn't dump the huge open left outlane instead of the VUK. This is the same setup I disliked in STTNG... I think I'll end up preferring the gameplay of the pro where there is some rubber over there.
I know you can earn kickbacks but still... seems more like work than fun to me.
I agree, you should cancel now.
Quoted from PappyBoyington:I agree, you should cancel now.
I'll wait and see how good this "added feature" is first I guess.
why everybody say the vuk is the main feature, i was thinking the ship crashing on the PF was the main feature with the laser dots.
when i first saw the picture of the vuk i was thinking how will the ball get around the ship from there, it needs a very strong kick out of there to make it happen.
2 years in the making and now they are changing this.
Looking at the Premium playfield again... that vuk had such a loooooooong way to go around. I'm just as confused as anyone though why it took them to the 11th hour to realize it was not going to work.
This page was printed from https://pinside.com/pinball/forum/topic/star-trek-game-play-video/page/20 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
