(Topic ID: 57136)
Star Trek Club.... Members Only!
By Jean-Luc-Picard
10 years ago
  • 10,689 posts
  • 858 Pinsiders participating
  • Latest reply 23 hours ago by Gaumax
  • Topic is favorited by 374 Pinsiders
There are 10,689 posts in this topic. You are on page 89 of 214.
#4401 7 years ago
Is this a problem all of us will face eventually over time ?
My pin isn't that old, less than a year.
If so did any one take some detailed pics and document fix?
#4402 7 years ago
Quoted from golfingdad1:
Mines going strong with over 1K plays. Hopefully I don't jinx myself here though.
#4403 7 years ago
It's a simple fix, don't sweat it.
The symptoms look really bad, but the fix is a cinch to implement. This is my first Pin and was my first fix, even I could do it.
#4404 7 years ago
Quoted from erak:
I hope there will be a xmas update to finish ST and get rid of the remaining bugs.
What bugs are remaining if you don't mind me asking?
I'm digging the new code, but if there's more to dig? I'm down for more new code.
#4405 7 years ago
Quoted from pinballpete:
Could this be an opto issue?
I saw the other the replies and they might be right....but it could also be the opto, it was on mine.
I had a loose wire on my opto connection (left side of center shot) pain in the ass to get to but I resoldered it and everything was back to normal.
#4406 7 years ago
Thanks guys! I wasn't clear the shim issue was effecting the Vengence. I will look into it. I didn't remember the drop target moving when the ship was acting up.
#4407 7 years ago
Yes, the shim issues effects the Vengeance. Basically, when the drop keep slipping off the bridge, the game interprets that as a hit on the Vengeance.
#4408 7 years ago
Black-out mod fitted - check.
LE mirror blades from Freddies fitted - check.
Coin taker's green laser arrived and ready for fitting - check.
Wife's arranged for us to go away and see her folks for the weekend.... check
#4409 7 years ago
Quoted from monkeyboypaul:
man i feel your pain, that shit always happens! hahahaha....and, "uhhhh noooooooo?" is not a good answer when your wife asks if you want to visit the in laws
#4410 7 years ago
Quoted from gweempose:
I just wish there was a way to modify the kickback so it had a little more, you know ..... kick. I don't understand what is fundamentally different about the kickback on ST, but it is way less consistent than any other game I own.
The actuator is wrong. Every other game with a kickback uses an "A" style actuator, whereas on ST, it has a semi-circle. That doesn't work because the switch is activated too far up the lane. With the A style (or whatever it's called, same as the shooter lane), the switch is triggered when the ball is much closer to the plunger, so it can be more consistent and the speed of the ball has less affect. On ST, it has to fire too early to try and prevent fast balls from getting past, but slow balls don't get much force as a result.
It's one of those things that just makes you go, crap, only Stern would do this. It's like when pf screws come loose on your games and fall out during play, or spotlights fall out, or GI flickers from loose 555's, you're like, geez, Stern.
#4411 7 years ago
You forgot the Stern Star_Trek Pop Caps...
which should be instock in the coming week.
#4412 7 years ago
Quoted from Zitt:
Those look great on my machine!
#4413 7 years ago
Atro - you used ice blue smt leds in the blue popcap, right?
I ordered some during Art's sale (even tho they weren't on sale); so may offer them as an option.
#4414 7 years ago
These caps look great !
I've heard getting to the bumper under the vengence can be a bit a of a pain.
Anyone have experience with this?
#4415 7 years ago
Yes and even more of a pain on the Premium/LE. But well worth the effort!
#4416 7 years ago
Quoted from Tuna_Delight:
Not what I wanted to hear, I have the Premium.
#4417 7 years ago
It's not too hard. 10 screws total I believe. You just need to go slow.
#4418 7 years ago
I have an LE and have the pop caps waiting on install....
Debating if I try to do it before the holidays or not.
#4419 7 years ago
Quoted from Meegis:
Take some pics and let us know how it goes.
#4420 7 years ago
I've heard getting to the bumper under the vengence can be a bit a of a pain. Anyone have experience with this?
I installed Zitt's pop caps on my LE. It's honestly not too bad. Just takes some patience and a steady hand. Zitt's installation instructions are excellent. Awesome product!
#4421 7 years ago
Gweempose is right - it's really not that bad. It just takes a little time. I don't relish removing any parts such as ramps or other assemblies as I invariably seem to make the process worse by dropping a screw and then end up spending as much time searching for it within the game as it should take for the entire process (thus the pain part for me). Either way, these are beautiful caps and I recommend getting them installed ASAP for maximum enjoyment.
#4422 7 years ago
It does not seem like in all the all threads listing bugs. That it would be extremely hard or huge issues to fix. Surprised it has been 9 months since the last update.
Im hoping they get fixed because I have had some great start games that basically ended or I had to end because of bugs.
Others like the missing sounds I could live with. But I would hope everything that needs fixing gets it eventually.
#4423 7 years ago
Please help with last part of the blackout mod:
The picture on their site sucks and I'm not sure where to hook this end up. I've got the board and other connector installed, just can't see where to hook up to the laser.
#4424 7 years ago
Quoted from pinball_erie:
The cable that goes off to get power from the laser? I think you just plug it up to the only similarly shaped plug up by the laser. Basically a pass-through.
#4425 7 years ago
Quoted from Zitt:
They look great on mine too! Don't forget to order the Vengeance Nacell mod and the Warp Ramp light mod while you're at it. (Pictured)S.T.G.C..JPGS.T.G.C..JPG
#4426 7 years ago
So this happened last night . . .
Always try to have double scoring active when you start 5 Year Mission. It can be pretty lucrative.
#4427 7 years ago
Quoted from crwjumper:
Nice!!!! That medal total alone probably beats a lot of people's Grand Champion scores ....
#4428 7 years ago
I'm still trying to get EA…couple weeks ago I was 1 shot away.
#4429 7 years ago
As others have stated; my PopCap install instructions are the best-known-method for installing on an LE/Premium.
Pro users have a much easier time as they don't have to remove the Vengeance.
Install Instructions are on the product page:
http://pinball-mods.com/oscom/modifications-bolt-on-mods-stern-star-trek-popcaps-p-31.html
#4430 7 years ago
+1 for Zitt's instructions.
I used them to change the rubbers underneath the Vengeance…the instructions made it so easy to do.
#4431 7 years ago
That's bad ass!! Love seeing that.
#4432 7 years ago
Quoted from Zitt:
And if you have the right kind of screwdriver and nimble fingers, you don't even have to mess with the Beta ramp. I was able to get the old cap off and the new blue cap on with this mini ratcheting screwdriver ...
http://www.amazon.com/gp/product/B000XYOUS6/ref=s9_al_bw_g469_i1
#4433 7 years ago
amazon.com link »
Sold!
#4434 7 years ago
It's a very handy little tool. I use it all the time when working on my pins.
#4436 7 years ago
Ditto.
Thanks for the tip Gweempose!
#4437 7 years ago
gweempose - I added that helpful screwdriver to our product page; incase it helps someone.
I expect to be instock with these sometime next week. I just have to confirm some LEDs and pull some packaging.
#4438 7 years ago
I was going to sleep and just some light reading before but now it's off for a game of Trek.
#4439 7 years ago
Quoted from BOBCADE:
Yup....your addicted.
#4440 7 years ago
Mine's at my folks lakehouse, all I can do is dream about it until I may the 6 hour drive
#4441 7 years ago
So I'm getting a loud buzz from the upper right flipper after some extended playtime.
I'll start looking at the schematics to figure out how the assembly goes together and the part names. But could somebody let me know likely cause?
Flipper doesn't stick or hang. Works normally. But after maybe 45 minutes of playing, it makes a really loud buzz if I hold the flipper button down. And when it does this, the loud buzz is intermittent.
#4442 7 years ago
Ok, so...if I do an upper right flipper rebuild only, no replacement of the coil, do I need to do any un-soldering or soldering?
I'm thinking I don't but would like somebody who's done this to chime in.
#4443 7 years ago
Quoted from investingdad:
No unsoldering should be required.
The sound you are hearing is fairly common with Stern games. My understanding is that it is normally the coil stop making the noise. i had it on my MET and after adjusting the coil stop it went away but that could have been a coincidence.
#4444 7 years ago
My IM was also making this noise....but it worked itself out over a week or so. Always played just fine.
#4445 7 years ago
Thanks guys.
I ordered a set of rebuild kits anyway, I'll need them eventually.
Now that I understand the schematic drawings and a little bit of reading, I'm going to try to tighten up the assembly and coil stop.
There's always been a hum from the flippers, but the angry wasp buzzing just started in the the upper right the other night.
#4446 7 years ago
Look for a broken coil stop, being that the center rivet is loose and the stop can move.
#4447 7 years ago
Not loose, but the coil stop appears to have a divot forming in the center.
#4448 7 years ago
Here's what worked for me. Lift up the pf and loosen the coil stop screws enough for it to be just a little loose (there's a fine line between loose and off), close the coin door and engage the flipper. If the loud buzz is gone, snug the coil stop and see if it's still quiet. Even though it doesn't appear like there's any room to adjust the stop, just loosening and tightening the screws seemed to be enough. Could also try pushing on the coils stop a little (while it's a little loose) to see if that fixes it, or push on it while the flipper is engaged. Obligatory warning to not electrocute yourself. I've fixed two flippers on ST and it was just that, messing with the coil stops.
#4449 7 years ago
pull the coin door switch out and leave it open.
#4450 7 years ago
Trailer is out for the 3rd Star Trek movie. I dunno....kinda makes me miss JJ directing.
NO GOUGE PINBALL™
Other
Filament Printing
Other
NO GOUGE PINBALL™
Other
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
$ 85.00
$ 54.99
Shooter rods
$ 649.95
Pin Stadium Pinball Mods
Led
$ 450.00
Duke Pinball
Decorations
Rice, MN
$ 18.95
KAHR.US Circuits
Displays
PinballSolutions.eu
Displays
$ 19.95
Mitchell Lighting
Led
$ 110.00
Shooter rods
8,000 (Firm)
Atlanta, GA
$ 95.00
Pinball Mod Co.
Sound/Speakers
Gilbert, AZ
$ 9.95
$ 290.00
Duke Pinball
Decorations
YouBentMyWookie
Other
$ 190.00
Lighting
Lighting
$ 8.00
Third Coast Pinball
4,000
Mesa, AZ
Pin Music Plus
Decals
$ 6.00
Apron Envy
Protection
Armor and blades
NO GOUGE PINBALL™
Other
$ 200.00
Duke Pinball
Decorations
Other
This page was printed from https://pinside.com/pinball/forum/topic/star-trek-clubmembers-only/page/89 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
