Quoted from Nokoro:I just got the Warp ramp light diffuser from Mezel. There was some discussion about this in the 1.61 bug thread, but since it doesn't really belong there, I thought I would post some things I noticed about it here.
First off, it is a big improvement. Not quite as bright as the normal inserts, but you can now definitely see whether the warp ramp is lit and what color it is.
Next, they kind of messed up with the design. There is a cut out on the right side (open side facing you) that you would think you are supposed to tuck the wires into. The only problem is that the wires are on the left side.
All that said, with a bit of adjustment, you can get a relatively decent fit.
I think they could have given a little more thought in the design of this, but overall it is a good product. I played one fairly vigorous game with it on -- 175 million; Klingon
MB twice; destroyed the Vengeance -- and it stayed on. Some have complained that the double sided tape doesn't hold it well enough. I guess time will tell. I know Eskaybee said that he used thicker 3M tape. That might be a little easier. We'll see if I eventually have to use that. I did have to cut the tape strips that came with it, as they were too big.
Still, good product overall. Just wish they would have double checked where that cut out was supposed to go.
