I have only adjusted the master volume control.
Ive had my vault premium about a month. Ball constantly gets stuck on that rubber under the pops. I can nudge it out but dont like wasting nudges! Any solution?
There should be a screw there that you can back out slightly to make a hangup less likely.
But the best solution is to make sure that the bottom pop is as sensitive as possible.
Quoted from DanQverymuch:There should be a screw there that you can back out slightly to make a hangup less likely.
screw under the playfield? Or above? it seems to me the rubber may be the problem. will take a look
Quoted from mbrave77:screw under the playfield? Or above? it seems to me the rubber may be the problem. will take a look
Screw is above.
Quoted from mbrave77:ok thanks. will take a look
Mine has a #6 washer under the screw. A small rubber may work better though.
Quoted from mbrave77:Ive had my vault premium about a month. Ball constantly gets stuck on that rubber under the pops. I can nudge it out but dont like wasting nudges! Any solution?
I put two small rubbers under the regular sling rubber. Reduces it almost completely.
All of my GI just went out.
I lifted the playfield bc the warp ramp started going nuts while I was crushing a vengeance multiball. It hasn't happened in months! Been solid.
So I reseated everything. Went to play and the gi isn't working. And all of those fuses don't have their red lights on.
Anyone have any experience, wisdom, or help? I appreciate it. Thanks guys.
P.s. the warp ramp thing seems to be fixed again. Hahaha. Always sumthin....
20210321_212650 (resized).jpgQuoted from Spiderpin:Star Trek up against GnR Round 3. Help put ST on top.
https://pinside.com/pinball/forum/topic/round-3-greatest-pinball-game-of-all-time-tournament-edition-2021
Bump. Only a few more hours. Star Trek falling behind needs your vote.
This isn't really a solution, but you are not alone ha. Every ST I've played, including my own, has had this problem. I usually just wait for the ball search and it comes out, it kicks into a search pretty quickly. If you have luck with an adjustment let me know what you did!
Quoted from Kjarkur:For the stern star trek. How do I activate the vengeance MB? Rules says hit x time vengeance. What number is x? Does it mean that I have to hit when target is down?
You have to hit the drop target like 6 times maybe. Then it locks the ball inside with the target down. Launches a new ball and you have to hit that captive ball to release it. Or, if you aren't very good aim like me, it will release after a time. Hit the black hole for add a ball.
Quoted from Kjarkur:What number is x?
"x" is adjustable, depending on how the game difficulty is set.
OK,
I finally figured out my auto launcher problem. I turned out to be the Cliffy protectors! I bought the 3 piece set and the side rail metal guard was fine, but the other two that install in the bottom left and right of the shooter lane were causing the ball to mis launch. The crazy thing about all this, was that it ALWAYS started off fine and got weaker and weaker as time went on until it couldn't even make it to the playfield! WTF?? This made me think it was an electrical problem. So be warned. My pitch is set at 7 degrees. And this is not something you can see by watching. I never had a problem with the Cliffy's on my other tables either!
Quoted from D-Gottlieb:Why 7? Have you tried the recommended 6.5?
Yes. And it plays much better at 7!!
LO, I have had that debate with my family. I hear "Kai". They think I am making it up.
Quoted from ectobar:Have to say, I'm a little disappointed in all you new ST owners. I feel like we're way overdue for a "Do you hear Kahn or Kai?" debate.
We revisit that every time my son comes over to play.
...and there is no debate, it's Kai.
Quoted from rollitover:We revisit that every time my son comes over to play.
Oh, no question it's Kai. I think the bigger debate is why they felt the need to remake probably the best Star Trek movie in history, and not just think of a new idea.
Quoted from Goonie:Oh, no question it's Kai. I think the bigger debate is why they felt the need to remake probably the best Star Trek movie in history, and not just think of a new idea.
And THAT my friend is the true debate here.
It's sci-fi... you can do ANYTHING! And yet we get a reboot!?!
Whenever I hear the Kai, my imagination responds to it with Jack Black saying KYle, like when he's angry at him.
So myself and Speedracer773 are both looking for the blackout mod that kapsreiter has previously made. He said he would do a small run if we get enough people interested. I believe 5 is what he required but I’m sure more is better. If anyone is interested reach out to myself or Speedracer773 and we can get this in the works. Thanks!!
Quoted from Flash71:So myself and Speedracer773 are both looking for the blackout mod that kapsreiter has previously made. He said he would do a small run if we get enough people interested. I believe 5 is what he required but I’m sure more is better. If anyone is interested reach out to myself or Speedracer773 and we can get this in the works. Thanks!!
Thanks Flash71 , We currently have 30-40% of the minimum order and we've only just started. If you ever wanted one jump on now. It's a fairly easy mod from what I understand, it works well, and is worth it!
Quoted from Speedracer773:Thanks Flash71 , We currently have 30-40% of the minimum order and we've only just started. If you ever wanted one jump on now. It's a fairly easy mod from what I understand, it works well, and is worth it!
What is it and how much?
It is taken straight from the movie. It sounds like Kai, the subtitles say Kahn.
Quoted from Happy81724:What is it and how much?
During Klingon multiball or whenever the laser is in use is will kill all the GI to make it more of an immersive experience. Very cool ! I think he was around $50 or so. Worth every penny IMO.
Quoted from Flash71:During Klingon multiball or whenever the laser is in use is will kill all the GI to make it more of an immersive experience. Very cool ! I think he was around $50 or so. Worth every penny IMO.
I’ll have to look if mine has it. It was modded prior so it might do that
He said it has the vengeance mod looking back at messages. I don’t think that’s the same
Quoted from Flash71:Yea Vengence mod is different. Anyone else who’s interested let us know !
Not sure if I’m on the list but for that 50 dollar range I am interested
It definitely sounds like Kai - exactly like it does in the movie since (as pointed out above) it’s a clip straight out of the film. I guess you’d need to fix the film also to make everything consistent.
i will do a realy final run now of the ST blackout mod for premium and LE
https://pinside.com/pinball/forum/topic/star-trek-le-laser-blackout-mod
tom
Quoted from Speedracer773:any chance you're making any more ST Popcaps? I've read lots of good things. It seems like there are several people with new pins (or new to them) looking to make some tasteful mods.
This was discussed here:
https://pinside.com/pinball/forum/topic/opinioninterest-check-stern-star-trek-popcaps/page/5#post-5874987
Once the reworked caps are made available by invitation only; that is it.
I will not be re-running the ST Popcaps as the vendor was the same that sent me garbage for the stng popcaps. As a result I wouldn't give them another bit of business.
So; if you want a set of pop caps when they are made available - you'll need to follow the post above.
Quoted from kapsreiter:i will do a realy final run now of the ST blackout mod for premium and LE
tom
Right on. Count me in. Seems to be interest for sure. PM coming. Thanks again for doing this.
Quoted from Zitt:This was discussed here:
I have signed up and anxiously await this opportunity!
Star Trek PRO Stern..... PIN2DMD ROM available or not ?
I can't figure out if there is a complete colorization done yet for S.T... On youtube it is being shown and presented. Though the comments state the file might not be complete.
Would anybody know ? Where could one find the file, if available... Having no luck over at V.P universe.
Matt
Quoted from Flippermatt:Star Trek PRO Stern..... PIN2DMD ROM available or not ?
Matt
There is 1 for the 161 rom version
https://vpuniverse.com/forums/files/file/4715-startrek-pro-161/
Hi, I have started digging out my collection of pinball machines and want to get them up and working again. I have a 1979 Bally Star Trek. The game was well played when i got it, showing heavy wear on the play field. It was not well stored. Now when plugging it in I get lights, two tones, one or two snaps from the flippers and then nothing. I do not see any corrosion on the boards. I'm a em
guy, no real experience with solid state. So I would appreciate any help. I have had some info on having the boards serviced but have no idea what a fair cost would be. Thank you for your time. Steve
Hi, I'm new to Pinside. Decided it was time to get my games out again and get them working. I have a Bally Star Trek. The game has been in storeage for 20 plus years. Plugging it in, I get lights, activating a new game I get two clicks, flippers work once or twice and that's it. I'm a em guy and do not know that much about solid state games. I have no idea on what to check first and how much things cost to fix. My game was well played when I got it showing wear down to the wood in the center of the playfield.
Any suggestions on what I need to do next to get the game going would be appreciated. Thanks, Steve
This page was printed from https://pinside.com/pinball/forum/topic/star-trek-clubmembers-only/page/192 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
