Quoted from Aurich:He said package.
Speaking of ... I've been getting people asking me about it lately. If I had maybe 4 more I could probably do a little run of them for folks. PM me if you have any interest.
In!
In!
Quoted from mnrocketry:Joined the club today. Bought a HUO Stern Star Trek Pro. Only mod in it is a shaker motor.
Don't forget Aurich's package!
Quoted from hoby1:Made up a shooter rod today. Turned out soooo well I’m not sure if I’ll dip in epoxy resin
O.K. Now that is pretty cool! Fantastic!
Quoted from hoby1:Then you have a lot of fun times modding ahead of you.
Ordered a bunch of stuff today!
Nice job, how did you do it? I bought that years ago to do it and never got around to it.
Soooo....did you just sand down the end of the shooter rod off to get it flat?
Quoted from Irishbastard:Soooo....did you just sand down the end of the shooter rod off to get it flat?
that's what i did for another game, works perfectly if the keychain or similar is the same size.
Quoted from beatmaster:that's what i did for another game, works perfectly if the keychain or similar is the same size.
Cool, thank you. What adhesive did you use? I have a new spare shooter rod and bought that pin on eBay a while back with intentions of doing this, just never got around to it.
Sorry....... yes I did it on a grinder first then a sander.
Quoted from Irishbastard:Cool, thank you. What adhesive did you use? I have a new spare shooter rod and bought that pin on eBay a while back with intentions of doing this, just never got around to it.
i used clear epoxy 50/50.
just like hoby1 said start ruff but finish smooth, go easy.
Shooter rod installed (resized).JPGQuoted from mnrocketry:Ordered a bunch of stuff today!
Hope you consider my blue Leg Lights for it. I'm just down the road. LOL
Apologies if it’s already been posted, but Stern is looking for the STLE owner #357. Link from FB: https://www.facebook.com/136972659243/posts/10158800129594244/?extid=flaNcUC9Ad8jt7dF&substory_index=0&d=n
Sorry if this is an common question but is the big enterprise ship in the rear of the playfield supposed to be a little crooked or should it be level? It's on a spring so I assume I can bend it but thought I would ask first, TIA.
Quoted from NYP:Sorry if this is an common question but is the big enterprise ship in the rear of the playfield supposed to be a little crooked or should it be level? It's on a spring so I assume I can bend it but thought I would ask first, TIA.
The Vengeance should be fairly level.
20200708_191508 (resized).jpgQuoted from NYP:Sorry if this is an common question but is the big enterprise ship in the rear of the playfield supposed to be a little crooked or should it be level? It's on a spring so I assume I can bend it but thought I would ask first, TIA.
Mine was slightly askew. I kind of liked it that way. It always made me think of a star ship coming out of a fast turn ready to attack.
Quoted from locdb:Apologies if it’s already been posted, but Stern is looking for the STLE owner #357. Link from FB: https://www.facebook.com/136972659243/posts/10158800129594244/?extid=flaNcUC9Ad8jt7dF&substory_index=0&d=n
Wish there was a way to get these remade as I have #508 and the certificate was lost by the previous owner.
Quoted from zephee:Hi Guys,
Does Star Trek Vault Premium have a shaker motor by default or is it an add-on?
Premium = shaker
Quoted from Viperbsd:Wish there was a way to get these remade as I have #508 and the certificate was lost by the previous owner.
Contact Stern, I have known them to replace a TWDLE certificate for an owner over here.
No - you have to buy it. It's an easy drop-in add-on though (get the S.A.M. version). All cabling and pre-drilled holes are in place on the Vault.
Quoted from gdonovan:Premium = shaker
That's incorrect. Vault Premium does not come factory with the shaker.
Quoted from GoodOmens:No - you have to buy it. It's an easy drop-in add-on though (get the S.A.M. version). All cabling and pre-drilled holes are in place on the Vault.
The flyer clearly indicates it does.
So I had the last mode of the first missions round active while playing Klingon multiball today. As the mission ended with Klingon still active, the Vengeance lights illuminated to start Kobiyashi Maru. Soon after, the flippers died and I figured the game was forcing me out of multiball to begin Kobiyashi. However, after both balls drained, the game ended with my ball 3 bonus and match animation. Now when I start a game, the ball eject fires twice and two balls are put into play. I have removed the balls, unplugged the machine, etc, but the error still occurs.
Is this the type of thing that a software reload can fix?
Quoted from gdonovan:The flyer clearly indicates it does.
It's a missprint that Stern never corrected (https://pinside.com/pinball/forum/topic/star-trek-premium-has-a-shaker). Unless my distributer/Stern screwed me on my NIB purchase...
Quoted from GoodOmens:It's a missprint that Stern never corrected (https://pinside.com/pinball/forum/topic/star-trek-premium-has-a-shaker). Unless my distributer/Stern screwed me on my NIB purchase...
My premium had a shaker.
Quoted from Flyfalcons:So I had the last mode of the first missions round active while playing Klingon multiball today. As the mission ended with Klingon still active, the Vengeance lights illuminated to start Kobiyashi Maru. Soon after, the flippers died and I figured the game was forcing me out of multiball to begin Kobiyashi. However, after both balls drained, the game ended with my ball 3 bonus and match animation. Now when I start a game, the ball eject fires twice and two balls are put into play. I have removed the balls, unplugged the machine, etc, but the error still occurs.
Sounds like a trough switch/opto problem. Try reseating any connectors going to them and make sure your solder joints are ok and the optos themselves are clean and aligned.
Quoted from Jediturtle:Sounds like a trough switch/opto problem. Try reseating any connectors going to them and make sure your solder joints are ok and the optos themselves are clean and aligned.
Okay so I started by removing, inspecting, and switch testing the trough opto. All checks good. I go to switch diagnostics and see the #4 trough ball switch shows active, even when all balls are removed. Perhaps the game registers all balls in the trough and determines one is stuck, launching again. A check of that switch finds a mounting screw had completely backed out - that must be it! So I remove the screw, check all wires, try to test it on the diagnostic page and it continues to show closed. In fact, all three switches on the red/white return line show active. The other two switches are the Red Target #6, which seems fine, and the upper opto switch under the Vengeance (ball lock). Sticking my finger in the ball lock, I can get the opto switch to show off when blocking the light beam. When I do that, the other two switches on the return line function normally. I can get to the right side, so I remove the plastic over it and notice the sensor is loose. That must be it! Tighten up the screws and.......nothing. Same problem. Getting to the left side looks pretty involved, with removal of the warp ramp and Alpha quadrant ramp. Before doing that, I grab some felt pads, jam them in the ball lock area to block the upper opto switch, start a game, and.......one ball ejects like it should. Looks like I'm in for a long afternoon of removing stuff in hopes that the problem is with the left side opto switch. Fun times.
Stern Star Trek Le was delivered via trade yesterday.Had a premium years ago and sold it to get something different. Big mistake.This low play Le is amazing. I think it’s the best Stern game built to date.kickass gameplay,and a spectacular light show.WOW
Wanted to share my new chrome apron logo solution: https://pinside.com/pinball/forum/topic/finally-new-chrome-logo-solution-for-data-east-aprons#post-5810505
IMG_4364 (resized).JPGQuoted from Flyfalcons:Okay so I started by removing, inspecting, and switch testing the trough opto. All checks good. I go to switch diagnostics and see the #4 trough ball switch shows active, even when all balls are removed. Perhaps the game registers all balls in the trough and determines one is stuck, launching again. A check of that switch finds a mounting screw had completely backed out - that must be it! So I remove the screw, check all wires, try to test it on the diagnostic page and it continues to show closed. In fact, all three switches on the red/white return line show active. The other two switches are the Red Target #6, which seems fine, and the upper opto switch under the Vengeance (ball lock). Sticking my finger in the ball lock, I can get the opto switch to show off when blocking the light beam. When I do that, the other two switches on the return line function normally. I can get to the right side, so I remove the plastic over it and notice the sensor is loose. That must be it! Tighten up the screws and.......nothing. Same problem. Getting to the left side looks pretty involved, with removal of the warp ramp and Alpha quadrant ramp. Before doing that, I grab some felt pads, jam them in the ball lock area to block the upper opto switch, start a game, and.......one ball ejects like it should. Looks like I'm in for a long afternoon of removing stuff in hopes that the problem is with the left side opto switch. Fun times.
You will probably find many loosened screws throughout the machine. They do cause issues like this and really need to be tightened occasionally.
Quoted from D-Gottlieb:You will probably find many loosened screws throughout the machine. They do cause issues like this and really need to be tightened occasionally.
Thank you, I am on the road now but just ordered a new pair of optos from Pinball Life in case mine are bad. Before I left on my trip, I was able to stick a pencil into the left side opto hole and it seemed that the opto was securely in place, so it may have just gone bad. I found an old thread here regarding upper opto issues in this game and I imagine my experience is not new. I was surprised to find no thread locker was used in the ball trough switches, I know it's not really an option when threading into plastic or wood but would be useful when threaded into metal. Looking forward to getting back home and getting the issue resolved.
Quoted from AJB4:I am upgrading my membership in the Star Trek Club - why, you ask? Because if I could have only 1 pin - Star Trek LE would be it....
yup, that's a nib LE
woo-hoo!!!
Best LE of all time!!
Quoted from zephee:Joined the club with a NIB Premium VE this week. Great game. I have a question though. The ST I played in the past had lasers that appeared on the play field. I think it was at the start of Klingon multiball but mine does not. Is that a mod? Or was that only on the 2013 model?
thanks
You should have lasers. Look at the front apron to the left of the drain. It should have a hole and a laser warning label.
15986689403302392583884898640891 (resized).jpgThanks. So the laser is there and the motor is activating. I stuck my phones camera in there when the mulitball started and it definitely looks like theres some lasers in there only I cant seem them on the playfield (video here https://photos.app.goo.gl/NPzGYrhSXVm6nsvn6). I took some picture. It almost seems like the projector is at a bad angle? Does this look normal? Any ideas?
MVIMG_20200829_122446 (resized).jpgMVIMG_20200829_123323 (resized).jpgI have seen them misaligned. You can take the lower arch cover off and bend the bracket if you need to.
woo-hoo!!!
woo-hoo!!! As they say where I come from. W T heck. I have a tricked out one and know your joy. Or the joy that’s upcoming.Congrats on a rare pickup.
that looks like the laser isn't "centered" on the hole.
Not sure a bend of the bracket is going to fix that.
Can someone take a picture from the same angle. I would; but mine is buried in some product right now.
Just to follow up on my laser issue as I was able to fix it. It really was not the angle of the laser (though it was off), it was the laser itself. I took off the apron and was able to verify the laser motor worked fine. Turns out there is a button on the laser mechanism that is being held down by a clamp. That button depresses another button inside the mechanism that 'powers' the laser. It needs to be depressed when the motor spins in order for the laser to shine.
Anyway, it turned out the outer button that is held down by the clamp was broken. It was knocked loose somehow and was not able to depress the inner button while clamped. I had to jury rig it. I just put in the end of a tie rap over the inner button and put the clamp down on that to get it to work.
Seems like a silly system to have since the two buttons are always pressed down.
Fixed now though so think i will enjoy the laser show a few times before tackling my shaker motor problem.
MVIMG_20200829_205141 (resized).jpgMVIMG_20200829_205338 (resized).jpgMVIMG_20200829_210058 (resized).jpgQuoted from zephee:Just to follow up on my laser issue as I was able to fix it. It really was not the angle of the laser (though it was off), it was the laser itself. I took off the apron and was able to verify the laser motor worked fine. Turns out there is a button on the laser mechanism that is being held down by a clamp. That button depresses another button inside the mechanism that 'powers' the laser. It needs to be depressed when the motor spins in order for the laser to shine.
Upgraded your laser with one of Zitt laser upgrades, the difference is night and day plus you can see the upgraded laser from Zitt in the day as well!
Check back for one of my posts in the last couple of months I took some photos at around midday, 1 in the afternoon with my blinds open to flood the room with daylight and you couldn’t see the stern laser, zitts was as good in the day as sterns was at night!
The stock laser is made from a laser pointer, a cheap item, and mine started to flicker badly due to the switch malfunctioning. I went with Zitt's laser mod and it works great now.
Quoted from zephee:That button depresses another button inside the mechanism that 'powers' the laser. It needs to be depressed when the motor spins in order for the laser to shine.
Quoted from J85M:Upgraded your laser with one of zitt laser upgrades, the difference is night and day plus you can see the upgraded laser from Zitt in the day as well!
Quoted from D-Gottlieb:The stock laser is made from a laser pointer, a cheap item, and mine started to flicker badly due to the switch malfunctioning. I went with Zitt's laser mod and it works great now.
Thanks guys.
Yes, sorry - I've had my lasers so long that
1) I didn't realize the "green" in your pictures WASNT laser light.
2) Forgot the stock laser pointer had a button.
zephee if you're in the market for an upgrade to Green or Blue; please let me know. I am planning to eventually do a Last Time Buy for Red... I just haven't made any definitive plans.
My lasers do not have a button, are more easily visible, and are bolt-on ready.
This page was printed from https://pinside.com/pinball/forum/topic/star-trek-clubmembers-only/page/174 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
