Quoted from MustangPaul:No, only every other game has a sub.
How did the sound improve?
Quoted from StylesBitchly:How did the sound improve?
I had to turn the volume down on the sub to get the same loudness and the base response was better and cleaner. For my ears anyway. Everybody is different.
Quoted from MustangPaul:I had to turn the volume down on the sub to get the same loudness and the base response was better and cleaner. For my ears anyway. Everybody is different.
OK, that makes sense. You got a stronger signal off that board than piggy backing off the cabinet woofer terminals. However, it works fine this way with the sub I have, but my hearing is shit. I'm deaf in right ear. So I'm not a good judge of audio fidelity.
Quoted from StylesBitchly:OK, that makes sense. You got a stronger signal off that board then piggy backing off the woofer terminals.
I think that's the way it works, don't know for sure.
The problem with any Laser kit is the Pro lacks the software hooks to "turn on" the laser at the appropriate time.
It would take someone one "patching" a Pro software stack with the hooks to turn it on. No one had taken that job.
Quoted from Zitt:The problem with any Laser kit is the Pro lacks the software hooks to "turn on" the laser at the appropriate time.
RedShiftLED would be the board for that, albeit with some custom code to detect start of multiball... kind of like the rising cross mod for Metallica Pro.
New Star Trek Code
V1.62 - June 5, 2018
- Fixed a presentation issue where solid shot lights in Destroy the Drill II were showing when they weren't available.
Now, all available shots blink including the roving 2X shot.
- Fixed an issue in Nero II where shots/lights were not being displayed correctly. This only occurred during multi-player games.
- Fixed an issue in Mode Select where mode select would not show up quickly between balls. This occurred during multi-player games.
- Fixed an issue in Kobayashi Maru where double scoring was timing out due to the presentation length of Kobayashi Maru.
- Fixed an issue in Kobayashi Maru where the background music was missing.
- Added sound FX and a longer light show presentation for the final shot in Kobayashi Maru.
- Fixed a problem if you Drill Down 3 deep in a mode, i.e play Destroy the Drill I, II, III. . When you get through the
last III mode, you could get robbed out of the second/third wizard mode (Enterprise Amok Multiball would not start,
and, if you made it to Five Year Mission, the game would instead start Enterprise Amok Multiball. After the last
wizard mode you couldn't start any modes for the rest of the game. It could also crash the game while in this state.
- Fixed an issue in Nero II where the shot count was not properly shown when interrupted by other modes/events.
- Fixed a bug that was causing the Magnet to ignore the "disabled" adjustment.
- Added audit for total number of one, two, three, and four players games that have been played.
- Added USA_12 Coinage 1/$0.25, 5/$1.00
- Added Sweden_3 credit pricing 1 credit for 10 Kr.
- Updated Norway coin door to 1/5/10/20 Kr for left/center/right/4th slot.
- Updated Sweden coin door to 1/5/10/2 Kr for left/center/right/4th slot.
- Updated Sweden dip switch setting default to Sweden_3 pricing.
- Updated Switzerland dip switch setting default to Switzerland_3 pricing.
- Updated UK dip switch setting default to UK_4 pricing.
- Added China Dip Switch setting (28 00111000) and currency, pricing, overrides, redemption, tournament, novelty, etc setting.
- Fixed an issue with replay score computation.
- Added ticket dispenser type "TICKETLESS".
- Added ticket dispenser motor rest time between ticket dispenses (AD_TICKET_DISPENSER_REST_TIME_MS) - default is 0 ms.
- Added ticket dispenser retries (AD_TICKET_DISPENSE_RETRIES) - if the ticket notch switch is not seen after a dispense, the system will retry
- AD_TICKET_DISPENSE_RETRIES times to dispense a ticket before marking the ticket dispenser as "jammed". AD_TICKET_DISPENSE_RETRIES default is 0.
- Fixed an issue where the ticket dispenser was still enabled after uninstalling redemption settings.
- Added timed game options to the redemption system.
- Added default redemption settings to the system for each country (DIP) install.
Hey guys. Don't go to crazy! Just bug fixes, nothing new.
http://www.sternpinball.com/game-code
Quoted from StylesBitchly:Anyone install the Mezel Mods Warp Ramp chaser LEDs? How did that work out? Does tape hold up long term?
I have one that came with the machine but never installed - it's my understanding they are "on" all the time?
Quoted from crwjumper:Polk PSW10 FTW.
amazon.com link »
Goes on sale from time to time too!
12" Polk $63 shipped!
Quoted from Mister_Furious:New Star Trek Code
Just curious, if you have the "Movie Soundtrack" on your ST, will you lose it if you update the code? I assume yes?
Quoted from Irishbastard:More
Yes you will, until someone puts it back in the new code. Or you could with Pinball Browser.
Quoted from lapean111:Yes you will, until someone puts it back in the new code. Or you could with Pinball Browser.
That's what I figured, Thanks....I will wait
Losing movie soundtrack was my first thought with this update. Will hold off and hopefully it gets updated. Most of the bug fixes, I'm not likely to even encounter or notice.
Man, it would really be awesome if someone took up the call on a laser mod.
Quoted from PWhiz:Most of the bug fixes, I'm not likely to even encounter or notice.
This was my first thought!
Quoted from mavantix:Should we all just upvote pinzzz post if we want a PM when the new version comes out with the movie soundtrack? Because count me in too!
Me three!
I think it is really top notch for Stern to fix these 'harder' bugs.
Especially the one where you would not be awarded the second/third wizard mode!
And finally the nero bug is solved.
One can only say: "THANK YOU STERN!!"
Quoted from DavidPinballWizz:I think it is really top notch for Stern to fix these 'harder' bugs.
+1
Now I need to find some time to update the code on mine
Quoted from InfiniteLives:bummed the code didnt fix the black hole award stuff oh well
What bug was this?
Naa!
This is how it should be!
If it wasn't for all the new competition in the market place, I doubt it would have happened.
But anyway, thanks Stern!
Quoted from PWhiz:Man, it would really be awesome if someone took up the call on a laser mod.
Then you would officially own a PROMIUM!
Quoted from J85M:What bug was this?
just stupid stuff like "pops score 2,000" or whatever but it doesnt actually change the pops scoring, nothing game breaking but kind of annoying and you would think it could be fixed easy to add in when they did these other fixes.
Quoted from Zitt:I guess I have to go find a hat to eat...
This guy say’s that you can have his hat. LOL!
Quoted from InfiniteLives:just stupid stuff like "pops score 2,000" or whatever but it doesnt actually change the pops scoring, nothing game breaking but kind of annoying and you would think it could be fixed easy to add in when they did these other fixes.
Have you given it a physical check to see if it’s been fixed? I have noticed changes on other games that where not listed in the update list readme.
Quoted from J85M:Have you given it a physical check to see if it’s been fixed? I have noticed changes on other games that where not listed in the update list readme.
I have not updated my code, I have the movie edit right now that I prefer over these changes at this time.
Quoted from StylesBitchly:Then you would officially own a PROMIUM!
Lol, that's actually what I call mine. I have around 20 different mods on my machine.
Quoted from PWhiz:Lol, that's actually what I call mine. I have around 20 different mods on my machine.
I didn’t even realise there was 20 different mods for ST
I counted mine last night. I have 21 and soon to be 22 mods..
1) shaker motor
2) sub woofer
3) topper
4) Aurich art package
5) color lcd
6) plastic protectors
7) under cab lighting
8) dmd guard
9) vengeance nacelle diffusers
10) vengeance visor kit
11) vengeance explosion mod
12) vengeance spring cover mod
13) nebula mod
14) warp ramp Chaser lights
15) warp ramp insignia diffuser
16) warp ramp red light insignia mod
17 flasher diffusers
18) drink holder
19) Star Trek insignia decal for drink holder
20) art blades
21 service rails
22) soon to be lighted acrylic speaker grills.
About the lighted acrylic speaker grills?
Anyone try the pinballbulbs.com (Stern Blue Speaker Light Kit)
https://www.pinballbulbs.com/products/stern-blue-speaker-light-kit
with the Acrylic Designs Star Trek grills
http://www.speakerlightkits.com/Acrylic-Designs.html
I’m wondering if the two will work together?
*** I don’t want color changing and remote control. I just want it to turn on and off with machine.
After investigating this option, it costs only a little over $6.00 more to just order the RGB light kit and acrylics from speaker lightkits.com and only pay shipping one time. Plus you get much more versatile system.
Quoted from StylesBitchly:I counted mine last night. I have 21 and soon to be 22 mods..
1) shaker motor
2) sub woofer
3) topper
5) color lcd
8) dmd guard
13) nebula mod
18) drink holder
20) art blades
21 service rails
Nice list. With my 2 mods you'd have 24.
Do you really count the drink caddy a mod? It really has no bearing in game play or visual stimulation!
I personally consider them to be a option. A option that will be on every machine I own so therefore it becomes standard to me. Kinda like flipper buttons!
Quoted from heni1977:It really has no bearing in game play or visual stimulation!
But it does visually stimulate me when I see a beer in it!
And the beer most definitely has a bearing on game play!
There would still be enough mods to make it a Promium.
So Cheers!
Quoted from heni1977:Do you really count the drink caddy a mod? It really has no bearing in game play or visual stimulation!
Did you know PBL has red and blue transparent removeable cup holders? They are way cool.
Quoted from MustangPaul:Did you know PBL has red and blue transparent removeable cup holders? They are way cool.
Can’t find them. Link?
Quoted from StylesBitchly:Can’t find them. Link?
Here ya go. My red and blue Pincup Light Ups really light them up. https://www.pinballlife.com/index.php?p=product&id=4539
Quoted from MustangPaul:Here ya go. My red and blue Pincup Light Ups really light them up. https://www.pinballlife.com/index.php?p=product&id=4539
I thought those cost more...I have one on my ST, that came off my Family Guy when I sold her...all my other pins have .50 cent Walmart cupholders
Quoted from Irishbastard:I thought those cost more...I have one on my ST, that came off my Family Guy when I sold her...all my other pins have .50 cent Walmart cupholders
The old design were $12.95 and this design was $13.95 I think. Looks like they don't sell the old design any more.
1) shaker motor
2) sub woofer
3) topper
5) color lcd
8) dmd guard
13) nebula mod
18) drink holder
20) art blades
21 service rails
Nice! Here's my list off the top of my head.
1) Aurich's art package(trans+decal set)
2) Pinball Refinery's custom led backbox(for Aurich's trans art)
3) Speaker RGB lights
4) Speaker grills w/SF emblem
5) ColorDMD
6) Vengeance nacelle diffusers
7) Vengeance visor kit
8) Vengeance explosion mod
9) Vengeance spring cover mod
10) Warp ramp insignia diffuser
11) Warp ramp chase lights
12) Asteroid cluster mod
13) Zitt's pop caps
14) Klingon BoP mod
15) Hallmark USS Enterprise ornament mod
16) Mirror blades
17) LED flipper buttons
18) Under apron light strip
19) Plastic protectors
20) Cliffy's protectors
21) Freddy's Alpha/Beta ramp protectors
22) Superbands flippers(blue lower, red upper), posts(various)
23) PDI glass
24) Custom movie soundtrack code
Oh yes, and a couple of drink holders.
Quoted from PWhiz:Nice! Here's my list off the top of my head.
13) Zitt's pop caps
14) Klingon BoP mod
Come on; I know you've install my other mods:
Nebula Mod
USS Kelvin
Warp Ramp LED
Or have you forgotten?
If you have a Premium or LE; you should look at these two other products:
GI_Dimmer /w Blackout
Laser upgrade
I remind everyone to check out the Comprehensive Mod List for Stern_Star Trek on my blog... I may need to sanitize it for the Vault build.
Promium indeed!
You should post some pictures!
