(Topic ID: 259652)
Star Trek/Bally/Score Display Issue
By Raff
11 days ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 10 days ago by Raff
    #1 11 days ago
    On playet 1,2 and 3 and the credit screen you can see numbers to the left that shouldn't be lit up IMG20200114190926 (resized).jpg player 4 score works good so i swapped player 1 out and put the player 4 digtal score in and it was faulty so its not the digtal score boards.
    Raff
    #2 11 days ago
    Quoted from Raff:
    On playet 1,2 and 3 and the credit screen you can see numbers to the left that shouldn't be lit up [quoted image] player 4 score works good so i swapped player 1 out and put the player 4 digtal score in and it was faulty so its not the digtal score boards.
    Raff
    Looks like a common connector problem...probably need to re-pin the score display connectors on the left side of the MPU board.
    #3 11 days ago
    Quoted from wayout440:
    Yes, first pay attention to the display blanking signal (orange wire), comes from the MPU board J1 pin 10 and goes to all displays on pin 10 of the display connector. A problem with it can cause ghosting like you're seeing.
    Also check that the start button switch contacts aren't shorting to the metal door which can cause display issues.
    #4 11 days ago
    With Classic Bally/Stern games it's best to unplug ALL the displays and then try each one individually at the Player 1 position. This is typically where the wire harness daisy chain for the displays starts (so J1 on the MPU to the Player 1 display, then from Player 1 to another position). By just testing one display at a time you can know for sure if it's an issue with the signals coming from the MPU or the display(s).
    #5 11 days ago
    Quoted from acebathound:
    I second this.
    Ran into this before and it turned out to be one of the displays itself causing issues with the others.
    Isolate the problematic display and work from there.
    #6 10 days ago
    The problem is at J1 connector i just moved the connector around a bit and the problem went away so looks like i will be repining pin 10 on the connector thanks to all.
    Raff
    $ 84.95
    $ 60.00
    Playfield - Plastics
    Vandelay Industries
    Monster Bash Remake Out of stock
    Flip N Out Pinball
    $ 69.99
    $ 5.00
    nvram.weebly.com
    $ 12,500.00
    $ 48.00
    $ 78.00
    $ 209.99
    $ 69.99
    $ 11.95
    $ 65.00
    $ 69.99
    $ 4.49
    $ 69.95
    pinballmod
    $ 229.99
    $ 17.00
    £ 75.00
    PinballToys
