I own a recently restored Star Trek Bally 1979 game. After a month of inactivity, I turned the game on but it began resetting during play. When the game restarts it goes through the same flashing light procedure that occurs when the power is first turned on. If the game resets, it won't push the ball out of the hole or if it ends up in the trough, it won't push the ball back to the shooter lane. Occassionally, the game won't start at all and stays on the solid green light, when it should dim the green light when it's ready for play.
I had the Alltek Ultimate MPU board installed professionally about 6 months ago and everything was fine, until a few days ago when the resetting issues started happening. I checked the voltage on Test Point 1 (with test point 3 connected to the black sensor) and it read a voltage of 4.80. The manual online says that "Any 5v reading of 4.85vdc or less is something that needs to be repaired"
I've never worked on a machine before, so I'm not really sure where to go from here. Is the low voltage reading from test point 1 actually the problem (I'm only guessing that it is)? If so, how do I go about addressing this?
