(Topic ID: 356936)
Star Post Rollover w/Hardtop
By pinballgurus_com
50 days ago
#1 50 days ago
I put a new hardtop on my Eight Ball Deluxe, but I’m not sure why the hole for the special was smaller than the rollover button? Any advice on how to fix this or make it work better. The rollover button barely moves enough to trigger the special button because it under the hardtop and the hole is much smaller than the star rollover button. I’m not exactly sure why they made the hole smaller, but I’m hoping I didn’t mess it up myself. Ideas appreciated.
IMG_0602 (resized).jpegIMG_0602 (resized).jpegIMG_0605 (resized).jpegIMG_0605 (resized).jpeg
#2 50 days ago
You need to remove the rollover insert.
Then sand, Dremmel, or router the Hardtop edges even with the playfield hole.
Then reinstall (or install new) (using epoxy glue) the insert, level with the top of the Hardtop.
It's a bit scary the first time you do it, but not bad overall.
#3 50 days ago
Quoted from RCA1:
Not sure why they would have done it like that? I figured they knew what they were doing so I thought that’s how it went on… this isn’t going to be fun. I’m almost tempted to 3D print a new insert that would work, before I cut on it but I’d rather do it the right way. I think my only hope is if I come up thru the bottom. I wish I hadn’t left the star post installed. It would have been far easier.
#4 50 days ago
They do know what they are doing. They had to do it that way since the location of star inserts (and everything else) varies a little bit between playfields for the same game. And also because the Hardtop does have some thickness to it. It's not hard. Here's Vid's description of the procedure:
https://pinside.com/pinball/forum/topic/future-spa-hardtop-install-vid-s-guide#post-5910357
I didn't sand the new inserts like Vid does and it was fine, so your mileage may vary.
#5 50 days ago
You could probably put an MRS there and leave it.
That's how I'd approach this.
#6 50 days ago
As others have said this is done because of small variances in playfields and there's no way they'd get it accurate with slightly different cuts. Is the hardtop already installed? If not, heat up that rollover and pop it out and then dremel and reinstall a new one at the correct level. It's actually not bad and works out well. If it's been adhered, you'll probably need to bust out the old rollover and remove it from the bottom which will be a pain, dremel it out and reinstall a new rollover.
#7 50 days ago
And you call yourself a pinballGuru
#8 49 days ago
Quoted from slochar:
We agree
#9 49 days ago
At this point you pretty much have to go this route. You csnt leave that rollover in there like that; ghetto city sweetheart.
#10 49 days ago
Done! Thanks for the advice everyone. Always a way to do it.
IMG_0618 (resized).jpegIMG_0618 (resized).jpegIMG_0621 (resized).jpegIMG_0621 (resized).jpeg
Third Coast Pinball
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
$ 18.95
$ 33.95
