So I wanted to change some bulb on the playfield on my Bally 86 and then realised that there's a cable welded to almost every light and then stapled on the wood... it's almost impossible to get the staples out, I tried with screwdriver and vicegrip but it's too hard and I was damagind the wood... so my question is what's the use of this since the lights seems already plugged anyway, can I just cut it or would I need to weld it back ?
edit: thanks for the quick answer guys! yeah that's a good ide to just bend it to replace bulb, but actually I was also planning to do some touchup acrylic paint and clearcoat the playfield so I'd need to remove everything to make this right... unless I tape every hole before clearcoat but even then if I need to repair some inserts it will be difficult with everything still screwed/plugged in under the playfield
