(Topic ID: 324547)
Stand up switch fires when flipper button is engaged
By UNCgump
5 months ago
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 5 months ago by DumbAss
#1 5 months ago
I have a perplexing problem with my Indy 500. The rear-most stand-up/light-up target often fired when I engage the right flipper button. It also sometimes fires at random when the machine is at rest. It otherwise nfires appropriately when hit. It does NOT fire if I give the machine a good nudge. It is most bizarre to me that the flipper seems to trigger it. Any tips? I am hoping to avoid having to replace the opto...
#2 5 months ago
I'd first check all the switch wiring for a wire broke off the switch or a broken off diode. Then go into switch edge test and test all the switches to make sure the display indicates the correct switch when activated.
#3 5 months ago
The same exact thing happened to ours at the co-op. I think we replaced a part but not sure which one. Maybe stevevt can chime in. It was his game and I think he ordered the part.
#4 5 months ago
The stand-up/light-up targets use an opto. This could get dirty, or possibly weak.
Disassemble, clean the optos and reassemble. I use a q-tip with windex.
Right now it looks as though you can't buy part number A-20401
So don't break it!
Check the pins on the board to the connector soldering very carefully for cracked solder, you might want to reflow the connector while you have it apart.
It's not uncommon to have to replace the plug connector to these switches. The IDC type connectors can be shaken to the point they make intermittent connection.
If the phantom triggering persists, take one of the other stand-up/light-up targets and switch places. If the problem follows, you've got a problem on the original target. If the problem persists in the same way with a different target, you've got a wiring problem or possibly a switch matrix problem.
Let us know what you find!
#5 5 months ago
Quoted from UNCgump:
In addition to the good advice already provided here, could you please clarify in your question whether by "fire" you simply mean the lamp flashes, or you mean that the target score is actually awarded as well.
That detail can help others who are less familiar with the general problem to both understand the problem you're having, as well as compare notes if they have a similar problem in the future.
#6 5 months ago
Quoted from pete_d:
It lights up, makes a sound, and awards points all as though it were hit. The switch others functions normally when triggered by hand with the glass off
I'll dig into it again soon and see what I can figure out. I may have to call in a friend with more experience, since I'm pretty naive on this stuff, especially electrical issues. Thanks to all for the thoughtful and helpful insights!
#7 5 months ago
I would start by measuring 12v power at that target switches opto board and report back.(Pin 1 is 12v)
#8 5 months ago
Quoted from PinRetail:
So don't break it!
They are available , pinball centre has them ... restored an Indy recently and replaced all 3...
#9 5 months ago
Quoted from transprtr4u:
Good catch! For US buyers Pinball Center will not directly ship to the USA, so it's a little harder for us to get these parts than it is for you in Alberta Canada.
Pinside user Zitt has made truly heroic effort to arrange parts shipping from Pinball Center, here is his thread, for anyone who needs parts that only Pinball Center has.
https://pinside.com/pinball/forum/topic/pinballcenter-parts-needed
#10 5 months ago
Just finished building 3 units.
$ 54.96
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
$ 29.95
PinSound
KAHR.US Circuits
$ 18.95
Filament Printing
Other
6,350 (OBO)
South Burlington, VT
Arcade Upkeep
Other
$ 5.00
Protection
This page was printed from https://pinside.com/pinball/forum/topic/stand-up-switch-fires-when-flipper-button-is-engaged and we tried optimising it for printing. Some page elements may have been deliberately hidden.
