(Topic ID: 76832)
ST Pro/Pre/LE Warp Ramp Insignia Lighting Mod -
By caker137
9 years ago
  • 67 posts
  • 25 Pinsiders participating
  • Latest reply 8 years ago by Arcade
  • Topic is favorited by 33 Pinsiders
There are 67 posts in this topic. You are on page 1 of 2.
25
#1 9 years ago
Have you noticed that the multicolor shot designator (insignia) that is mounted above the warp ramp doesn't illuminate quite as well as the ones in the playfield? Would you like it to? Easy:
Before:
After:
Here's what to do:
Step 1: Prepare these 2 parts. You will need a piece of cardboard (any but not too thick) and a piece of plastic milk jug (the thin translucent variety). Cut with scissors to these shapes (approximate is fine):
Step 2: Attach double stick tape to the back of the cardboard where it will hit the LED board:
Step 3: Pull the playfield out a bit so that you can access the back of the LED board assembly. It should look like this from behind:
Step 4: Loosen the LED board and rotate it lower so it is centered in the Insignia better. Re-tighten in this new position:
Step 5: Attach the milk carton piece to the back of the plastic insignia stack with a few pieces of scotch tape. This will help to make the entire insignia light up uniformly:
Step 6: Attach the cardboard to the front of the LED circuit board with the double stick tape. The cardboard helps to block out the back panel GI lighting and gives better contrast to the insignia:
(detail from above)
That's it! Pictures don't really show how well this works. The insignia lights up almost exactly like the ones in the playfield after doing this. Enjoy!
#2 9 years ago
What creativity! Nice job.
#3 9 years ago
WOW, fantastic. Great job!
#4 9 years ago
There's a few guys here that would sell that for $25
Thanks for sharing sir!
#5 9 years ago
Quoted from PW79:
Ha, so true, so true
#6 9 years ago
Quoted from PW79:
funny thing is, i was going to make one for this, just didn't have the time , yet.
$25 for a piece of plastic is a lot of money when you think about it, so if i do one i might sell it for $24.
caker i like what you did there, thank for sharing!
#7 9 years ago
Quoted from beatmaster:
Ah man, beatmaster you are too funny.
#8 9 years ago
Thanks for sharing. Going out to buy some milk. Do I cut the plastic shape out after or before i drink the milk?
#10 9 years ago
Nice work. I've done similar things with diffusers inside flasher domes with LEDs, they often benefit from something spreading the light out. The even light vs a hot spot can be a world of difference.
#11 9 years ago
Does it even need to be cut into a specific shape? If you cut both pieces into an oval that you can't see from the front would it work?
Edit: Never mind I see there is a 44 socket in the way.
#12 9 years ago
I can't loosen the screw on step 4 . Its driving me crazy , There is only a small space there and the screw is so tight I can't budge it . Went down to bunnings for a small screw driver with some grip , and nothing can be found other than jeweller ones ( the grip is too small and you can't get enough purchase) and the other ones are too big and too long to fit between the back lighting panel and the screw . What does everyone else use here?
#13 9 years ago
Try gripping the screw driver with a locking pliers.
#14 9 years ago
Awesome. Thanks for sharing.
#15 9 years ago
Quoted from MustangPaul:
i gave up, and i don't give up easily .spent all afternoon on it , used so many different methods , screw won't budge. i think they glued the sob in there. i need a l shaped screw driver to get some leverage but no one sells them around here , so i will try that one later. i did the plastic and cardboard so its a fair bit better but there is a portion on the bottom left of the insignia sign that needs more light . moving the led down would have fixed that i recon. oh well .
#16 9 years ago
I did a similar mod by building a little "tent" behind the insert to try and contain the light. I had trouble loosening the screw as well but I was able to slightly rotate the LED board without needing to loosen the screw.
#17 9 years ago
Very cool mod
2 months later
#18 9 years ago
I made a diffuser and cover, I looks awesome. I 3d printed an opaque diffuser and a black box to block the outside light. It installs with double sided tape. No tools required, just a repositioning of the light if it is not centered.
#19 9 years ago
Looks great. Gonna have to do this if I wind up getting a ST. So many cool mods coming out for it now that it's making it easier to lean that way.
Maybe someone like Pinbits will contact you to build them with their cutter. Would be super nice to have them make a case (kind of like their AC/DC lightening bolts). Have the diffuser piece cut the same size as the plastic then have another plastic (out of a dark color) cut the same size as the plastic with a whole for the light board to shine through.
#20 9 years ago
Quoted from 85vett:
I edited my comment above.
#21 9 years ago
That looks and works really nice. Gonna make more?
#22 9 years ago
Yes, I am sending one to a Premium owner to install for testing.
#23 9 years ago
Ok Tim - shut up and take my money - we know it will fit mine as you and I both have Pro's
Happy Birthday BTW
Jim
#24 9 years ago
Quoted from Tmezel:
I will take one if you decide to sell the mod.
#25 9 years ago
Quoted from Tmezel:
I'll let everyone know how it fits when it gets here.
#26 9 years ago
Quoted from TomGWI:
IM in too!
Quoted from Aurich:
I need to get down there and check out your premium!... And shadow
#27 9 years ago
Quoted from Eskaybee:
I need to get down there and check out your premium!... And Shadow
You've got an open invitation, any time.
#28 9 years ago
I am in on this!! premium should fit the same as pro
#30 9 years ago
Quoted from Aurich:
Oh sure...it figures you'd get the first one.
#31 9 years ago
Now that it lights up nicely, I see that it has something do with making shots when it is lit. Cool.
#32 9 years ago
Quoted from Tmezel:
Where is mine
#33 9 years ago
Quoted from Tmezel:
that why sometimes we couldn't see what to shoot for... well, we couldn't see much.
#34 9 years ago
I can't believe that looks so amazing! I wish I'd seen this thread a lot sooner...
#35 9 years ago
Agreed, looks much better thanks for posting the pics and instructions us pinball addicts out here salute you!
#36 9 years ago
Just did this about an hour ago with great results.
Thank you.
#37 9 years ago
I am down for one of these also! looks great
#38 9 years ago
Mine might even be more jury-rigged in terms of construction, but thanks so much for the fabulous suggestion!!
Same basic milk-jug mod, but I just stuck a bell-shaped piece of paper over the back of the assembly; can't see it from the front 80 degrees or so, so it's all good!!
#39 9 years ago
Quoted from TomGWI:
I will sell these for a reasonable price, but the DIY approach works too, if folks don't want to spend the money.
#40 9 years ago
Quoted from Tmezel:
Are they ready yet
#41 9 years ago
Quoted from PunishersLEMC:
Are they ready yet
You can haze Aurich now, it's almost in his hands now
#42 9 years ago
Thanks for the great idea, took some frosted vinyl that I have for my graphic work and stuck it on the back. Also did the same on the area on the playfield by the pop bumpers to diffuse the flasher a little bit. Cheers!
#43 9 years ago
Quoted from Tmezel:
I have a pro like yours - we know yours works
#44 9 years ago
Yeah, your right, I going to play it right now!
#45 9 years ago
Quoted from Tmezel:
Didn't come in today's mail, so I cannot report on anything.
#46 9 years ago
They should be identical sell sell !!
#47 9 years ago
Quoted from The_Dude_Abides:
Glad you guys are enjoying this! I know it made a big difference for my game.
#48 9 years ago
Quoted from Aurich:
You just did.....it didn't come in the mail.
#49 9 years ago
I have had to teach myself to be patient. Anyway off to Texas.
Trade
Machine - For Trade
Islip, NY
$ 24.00
Pinhead mods
Protection
$ 399.95
Pin Stadium Pinball Mods
Led
$ 24.75
Precision Pinball prod.
Flipper parts
11,000 (OBO)
Ocala, FL
Men
Other
This page was printed from https://pinside.com/pinball/forum/topic/st-proprele-warp-ramp-insignia-lighting-mod- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
