The right two enterprise inserts are lit by a single led on a small board as opposed to a regular socketed lamp. These inserts are a little trickier to get to which, I would suspect, is why they used these boards as opposed to a traditional socketed lamp.
Unfortunately, these single led's are not NEARLY as bright as the lamps in the other inserts and it bugs me becuase combos are a huge part of the game.
Has anyone replaced these boards with a socket and brighter led? (I'm thinking a flexi would work well) If you have, would you mind showing a picture of your handiwork and the part numbers you used?
Thanks in advance for any thoughts and comments.
