OK, I started the process to install a backboard decal for SS and as typical, its much more involved than expected. So, I'm removing the ramps and then discover that I cannot remove the spider ramp without removing the stiff coffin assembly. The problem is I cannot see how I can remove the stiff coffin without removing the spider ramp (it appears to wrap around it). Has anyone did this before and if so, how did you get that ramp removed?
Thanks,
Greg
