I searched for this issue and couldn't seem to find anyone having the same. I'm working on a pin for someone and I've got it all working except the chimes while in game.
The chimes all work fine, because when you press start to begin a game, it gives the start up tune.
In game, no chimes for any scoring, no matter what switch is hit. Game does score properly.
Things that may be important to know:
-Some owner at some point eliminated almost all connectors and soldered every wire from edge connector to edge connector. They actually did a decent job and I've checked continuity from the wires to the nearest components and it seems solid. Not ideal, but does the job.
-I've added the ground mods from pcbs to the ground plane, as suggested in Clay's guide.
-I've added the pullup resistor to the Kings reset coil transistor under the playfield.
-I see a tiny amount of corrosion from the old battery, but really hardly anything. I'll attach a pic.
This is my first system 1 repair. Thanks for any suggestions.
-RC
